Question about Dell Dimension 3000 PC Desktop
Blue Screen with error 0x000000ED
I cannot start my pc and any mode all i get is a blue screen with the following error message 0x000000ED (0x8A617E30, 0xC0000006, 0x00000000, 0x00000000).
Would appreciate any suggestions!!
  • Anonymous Mar 18, 2014
    0x000000ed (0x8a73ec08, 0xc000009c, 0x00000000, 0x00000000
    President:
  • 2,559 Answers
This behavior can occur if either of the following conditions is true:
  • Your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and the following conditions are true:
    • You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
    • The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
  • The file system is damaged and cannot be mounted.
The purpose of this error message is to prevent the following two things:
  • Potential data loss caused by using an incorrect IDE cable for the faster UDMA modes. An IDE cable is a kind of cable used to connect storage devices, such as hard disks, inside a computer.
  • Continued access to a drive on which the file system is damaged
Some things that you should know before you try this solution loadTOCNode(4, 'resolution');
  • If the file system is damaged, you can use chkdsk /r command to repair the volume. However, if you use the chkdsk /r command, you may lose some data.
  • You will need the Windows startup disks or the Windows installation disk. If you do not have them, contact the computer manufacturer for help in obtaining the disks.
  • You will need the administrator password to complete the steps.
To repair the volume, follow these steps:
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Note:
  • If your UDMA hard disk is connected to the controller with a 40-wire UDMA cable, replace the cable with an 80-wire cable.
  • In the BIOS settings for your computer, load the 'Fail-Safe' default settings, and then reactivate the most frequently used options, such as USB Support.
  • Posted on Jun 03, 2009
    Hello i don't know how are you .but i know your problem .
    solution: first you take a windows xp cd /dvd .
    then you insert the cd into cd or dvd ROM.
    when the cd will be booting
    then you get a measeage blow on black screen .
    the measeage is please press any key .then you press enter.
    after the booting .you get 3 option
    1: To continue the process press {Enter}.
    2: To Ripear your windows files press {R}.
    3: To Exit from this menu press{F3}.
    THEN YOU MUST PRESS {R}
    THEN PRESS ENTER.
    THANK YOU FOR SHARE ME THIS PROBLEM
      Problem Solver:
    • 16 Answers
    Plz format ur c drive than ur problam are solved
    UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
    try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
    Nov 13, 2012 | Dell Latitude D505 Notebook
    I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
    Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
    Best Of Luck
    May 07, 2011 | Computers & Internet
    Windows 7 Blue screen at start up. Shows "Starting Windows" then memory dump/ blue screen. Recovery = No points created by the owner. Roll Back = Tried the 3 points for installs which all still...
    Operating System does not respond is the major problem.
    This is a very commonly faced error by the users of the Windows 7 which leads to the Blue Screen of death to the system. The error message appears on the computer screen in the following form: "Windows Operating System is not responding" along with two options one "Close the Program" and other "Wait for the program to respond". But whenever the user attempts to close the program he comes up with a serious data loss. To solve this problem apply different troubling shooting methods or take help of the technical experts.
    Jan 12, 2011 | Toshiba Computers & Internet
    Blue screen error
    The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
    If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
    Follow these steps to fix a Blue Screen in Safe Mode
    Once booting start, select "Safe Mode" from the boot menu.
    Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
    Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
    Aug 27, 2010 | Microsoft Windows XP Professional SP2
    Unmountable boot volume + how to fix. Have reboot CD's Errors messages 0x000000ED, 0x8137DE8, 0xC0000006, 0x00000000, 0x00000000 can't get past this screen. keep circling around F8 and the Dell start-up...
    Turn off your pc and take the side panel off and remove the cmos battery leave for three minutes
    and then replace this will reconfigure your
    motherboard and hopefully solve your problem.
    Feb 15, 2010 | Dell Dimension 2400 PC Desktop
    Problem with windows. It won't boot up
    this only problem with windows or virus....
    you can use recovery to solve this problem..nothing else...check and it will work fine
    Jan 08, 2009 | Dell Inspiron 6000 Notebook
    Blue Screen Error Message
    Looks like you've been getting two different Stop errors...
    The 1st error, 0X00000024, aka Stop 0x24, is a Windows 2000 error. (XP is just an updated version of 2000) Microsoft gives an explanation here.
    For the 2nd error, starting with 0x000000ED, Microsoft's solution is here, with additional help here.
    Jan 02, 2009 | Dell Dimension 3000 PC Desktop
    Cannot reboot IBM thinkpad t-21
    There must be some driver you have installed recently. Try booting in safe mode and restore your system to an earlier date.
    Oct 16, 2008 | IBM ThinkPad T21 Notebook
    Dell Dimension 3000 PC Desktop Logo
    1,147 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
