Question about 2wire 2700HG-B Router (2700HGB)
Cannot connect to ethernet using 2 wire router
Suddenly I get a red light and a green light for wireless only (no light for the ethernet connection). Of course the wireless won't work since I can't connect to the ethernet. I've read some of the other questions and I'm guessing you're going to tell me I need to buy another router. If that is true, I guess I'll shop around and look for another internet provider (and I guess new phone service - I'll get a better deal if I bundle somewhere else).
I'm not very happy with AT&T. The internet locks up and I have to re-start. Although the speed is somewhat faster than dial up, the screens don't load very quickly. Due to the slower than desirable speed, some screens never load and I get an error message. I think we're paying to much for crappy service - especially if we have to buy a new router!
  • Prasanth Vignesh May 11, 2010
    wats the model number of the router and do u have a user name and password to connect to internet....please revert back with answers for more assistance....... :)
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:
check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.
May be it can be cause of Incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
***If you need any kind of technical assistance you can contact support cell at here
Feb 01, 2013 | Actiontec GT704WG Wireless Router...
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
I have a 2 wire wireless router. Both computers
you should your lan to ruter cable install it again carefully.
Feb 20, 2010 | 2wire (1000-400108-001) Router
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
moz-screenshot.pnghttp://www.ikarmatech.com
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Modem light is red won't stay green.
Make sure to configure the router according to your ISP settings. I believe you have a DSL connection. That means you need to configure the router using PPPoE
Apr 26, 2009 | Arris Wireless G Broadband Router (wr850g)
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
Internet Light Stays Red on WAG54GS Wireless Router
If your router's internet light is red it means to say that there's no connection. You really have to call Tesco.
Aug 21, 2008 | Linksys (WRT54GC) Router
Set up of adsl router
Try resetting the device to the default factory settings. Then see if you can get an IP address, either wireless or ethernet, to configure the router through its web interface.
Nov 18, 2007 | Belkin (F5D5231-4) Router
2wire 2700HG-B Router (2700HGB) Logo
230 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
