Question about Mintek LCD TV Progressive Scan DVD Player
Buttons don't work
My TV's buttons won't work. The only ones that do are the main power button and the power button on the remote. I tried to play a DVD on the built in player but now it wont eject. Sometimes if i turn it on the display is very very dim . I unplugged the the tv from the power socket and some the power indicator light still stayed on. This all happened so suddenly one time it worked the next time it didn't
  • 13 more comments
  • tfitz Nov 12, 2007
    I am having the same exact problem...anyone have a solution yet?
  • gmbrayboy Nov 15, 2007
    Same problems with my tv. The only button on the right that works is the power button. The dvd player will not accept a dvd and none of the buttons on that side work. Tried to locate a Mintek web site to find a solution but there is none, nor can I find any support for the tv.
  • mhintze Nov 17, 2007
    I have the exact same problem, and have tried similar if not the same measures to figure it out. At first it was stuck on one channel. Then after attempting to play a DVD it was stuck in DVD mode. I took apart the case and pulled out the DVD but now the TV is stuck in DVD mode.
    MH
  • cobratouch Nov 18, 2007
    It seems that I'm having the same issues. The only button that works is the power button on the set and the remote.
  • Branjar Dec 22, 2007
    My TV has the same problem the only button that works are the power and remote power. I have a disk stuck in the machine so I have no picture now as well. The set is 1 year old. Help !!!!!!
  • Anonymous Jan 03, 2008
    tv does nothing, only power button works, also have a dvd stuck in unit.
    tv is 1year old.
  • ttlachat Feb 22, 2008
    Same problem, stuck at first in TV mode, put a DVD in, and now it is stuck in DVD mode. I heard that Mintek was in Bankruptcy, and that is why no assistance is available. Anyone hear anything different??
  • Anonymous Feb 29, 2008
    DVD MENU IS ON THE SCREEN - BUT NOTHING WORKS! CAN'T EVEN PLAY THE DVD. NONE OF THE BUTTONS ON THE SIDE WORK! VERY, VERY FRUSTRATING!!!!!!!!
  • squire21 Apr 05, 2008
    Help, buttoms dont work, dvd stuck.
  • Anonymous May 11, 2008
    screen does not on
  • Fitz7600 Jul 21, 2008
    Same problem. Bought it from Costco 2/2007.
  • mjblasi4 Sep 20, 2008
    no buttons work its stuck on dvd and wont play
  • marvoshita Oct 25, 2008
    My tv won't switch channels or change volume and dvd is stuck inside.
  • georgejayne7 Nov 02, 2008
    I have the same problem. I'm a electronic technician. I opened it up but wasn't able to see an obvious problem.
  • NYMistral Mar 09, 2009
    It is just like the description above
    Problem Solver:
  • 14 Answers
Here is the fix:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Posted on Mar 15, 2008
I purchased my Mintek from Costco and had the same problem. They are aware of the problems with Mintek and lack of support. If your set is from Costco or other stores try them for a solution or refund. It worked for me. I got a full refund. Most retailers have a copy of the reciept if not try anyway.
Good Luck
Posted on Dec 24, 2007
SOURCE:
Buttons on the TV nor the remote control don't work
So the power button is the only one that functions? Double check your main board, IR sensor, and key controller connections. You should not need a code at all. The only programming you should have to do is to do a scan for antenna channels you may use as well as setting up any of your personal preferences. Did you order the exact part # as the old one?
Nov 12, 2013 | Vizio SV420M LCD TV
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My volume up on the Harmony 880 won't work. I've heard that one person did take it apart to clean the contacts, but that didn't solve the issue. Any suggestions? I don't even care if I...
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
Aug 14, 2011 | Logitech Harmony 880 LCD Remote Control
Hi, My Samsung DVD player remote would not respond when power button pushed on. When DVD power turned on Manually and DVD loaded the remote would not respond to the play, arrow buttons eirther?? My LG...
If the buttons on the case are working but the buttons on the remote don't then it's clearly a fault with the remote.
Each button in the remote is made out of 2 wires on the electronics board that are joined by a small patch of conductive paint situated on the rear of the rubber button. If something gets in there, like water or dirt or the patch flakes out, the contact is no longer made and the button no longer works. The remote will have to be dismantled by popping the clips on the periphery with a sharp tool, the rubber strip holding the buttons will have to be washed and the board wiped clean. If the buttons still don't work after that then the remote is dead, you will have to get another one.
Jul 24, 2011 | Televison & Video
Need remote code for 22lv505 for dish network
Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
How to program your dish network remote for your tv:
1. Use the device’s buttons or its remote control to turn on thedevice.
2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
4. Use the number buttons to enter one of the device codes that I have given you.
5. Only for Limited Mode, Press 1.
Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
You cannot change the tv channel when the remote is in limited mode. You can only power on your
VCR in limited mode
****Note: Skip this step if you do not want to use Limited Mode.****
________________________________________________________________
6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
** Stop Here**
Let me know if this helps..
1388f48.jpg If I have helped you, dont forget to rate!!!
Jan 03, 2009 | Toshiba 22LV505 22 in. LCD TV
Mintek LCD TV Progressive Scan DVD Player Logo
366 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
