Question about Refrigerators
No Cooling in the Fridge section, freezer is icing
I have Westinghouse Freestyle BJ504Q-R Upside Down Refrigrator. It's been working fine for the last 9 years or so but stopped cooling in the Refrigrator section two weeks ago. An A/C Technician offered assitance and tried to diagnose the problem. It was found that the Compressor wa working fine, Fan was working too, Defrost Heater worked too when engaged manually. He decided to replace the Defrost sensor and the timer. But that did not help. The freezer section started gathering ice and the fridge would not cool at all or very little (16-8 C). He then replaced the thermostat, but that did not make any difference. Another thing we noticed was that when we opened the freezer door, cool air would start to come into the fridge section but would stop if the freezer door was closed. This seems to suggest that the fan is not blowing cool air into the fridge section, as a result the thermostat is not stopping the compressor and hence icing in the freezer section.Having already spent quite a bit on parts, any advice to fix it cheaply would be appreciated. Else it's time for a new fridge.
  • tazeemn Jun 03, 2009
    I was unable to find any adjusting device. Is there a possibility for the fan to be working in reverse? And how about the fact that air starts going into the fridge section when the freezer door is open?
Unblock the ice or obstruction to the drain pipe from the freezer to the top of the compressor. make sure the little metal thing is over the heater element and hanging in the drain hole so it heats when the defrost element comes on.
Posted on Nov 09, 2011
Generally on these models they rely on cold air being pumped fr\om the freezer to the fridge and have a adjusting device to control the flow, you need to locate and check this is free and working properly. Another reason for freezer ice up is a shortage of gas in the unit, this is usually unfixable as the leak can rarely be found as it usually occurs within the cabinet case. Sorry to say it would then be a throw away.
Peter
Posted on Jun 03, 2009
  • vikketer
    vikketer Jun 03, 2009
    Peter
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Refrigerators
Got a 9yr old w/house fridge/freezer model BJ504Q. Had the defrost heater element replaced 4 weeks ago While the heater works it is not it is not defrosting the upper part of the element which is still...
If you cleaned it of all frost and ice and it keeps doing this then perhaps the defrost thermostat is detached from where it should be or shutting off too early. Try replacing it if is attached well.
Oct 27, 2010 | Refrigerators
Freezer works no refrigrator
most common fault to cause this problem is cooling element in freezer section iced up. could also be faulty fridge stat not letting cold air through.first pull drawers out of freezer section, if back cover inside feels frosty or snowy, then likely evap (cooling element) is iced up.if so empty cab, switch off for 24 hours with both doors open, and restart. ice ups can be the result of the freezer door being left ajar, but can also be a problem with auto defrost as well as problem in refrigeration circuit. if problem comes back call a service engineer.
Feb 27, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Refrigerators Logo
854 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
