Question about Canon imageRUNNER 400S Copier
Canon ir 400 photocopier
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 805 as soon the machine is started I have canon a simlar problem E805-002 but fan rotate properly if i open front cover & fixing side cover its display 805 error
I have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
    Sergeant:
  • 199 Answers
The general soluation as sm is below, but I think in your case there are some loose wiring or earting problem.
E805 The fan rotation has a fault.
• The fan has a fault.
• The DC controller PCB has a fault.
• The fan connector has poor contact.
E805 - ........ please see below
0002 Fixing heat discharge fan 1 (FM2)
0003 Fixing heat discharge fan 2 (FM3)
0004 Laser driver cooling fan (FM4)
0005 Laser scanner motor cooling fan (FM5)
0006 Laser scanner motor cooling fan 2 (FM6)
0007 Cleaner heat exhaust fan (FM7)
0008 System cooling fan (FM8)
0010 Low-voltage power supply cooling fan 1(FM10)
0011Low-voltage power supply cooling fan 2 (FM11)
0012 Reader cooling fan 1 (FM12)
0013 Reader cooling fan 2 (FM13)
0014 Drum cartridge cooling fan 1
0015 Drum cartridge cooling fan 2
0016 Drum cartridge cooling fan 3
0017 DC controller PCB cooling fan
0018 Scanner motor cooling fan
E805
Posted on Jun 03, 2009
Apr 19, 2009- Press additional functions
press #
press + key until display reads #7 printer
press set
press + key until display reads #4 printer reset
press set
press - key for yes
unplug copier wait a minute and plug it back in
This resets E-000 codes maybe that will help
Good luck
I found this on someones elses solution maybe it will help you...
Posted on Aug 24, 2009
May be one of fan doesn't rotate well there are two fan
Ihave canon ir 400 machine but thats no worked. machine displayed error cod E805 .sir please give me sugestation
E805The stoppage of the exhaust fan is detected, or a failure in rotation of the fan is detected. (iR/GP400 or later machines)The detail code, which can be checked with DISPLAY,
You can try to clean up the fan
Apr 14, 2018 | Canon Office Equipment & Supplies
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
The error code means that the hard drive has crashed or is failing. To resolve the problem you will need to replace the hard drive and have it flashed before you get it. Or call the place you got the copier from and have them send you another hard drive or return the copier back to them... Good Luck
Jun 06, 2013 | Canon imageRUNNER 400S Copier
Ir 400 error 805 002
Your connector is not good is connected to the DC control board. That connector is J112, which is located in top 3 of left to write.
Jun 12, 2012 | Canon imageRUNNER 400S Copier
Machine canon ir 400s error E051
hi sir my xerox machine IR 400 the error code e220
May 12, 2012 | Canon imageRUNNER 400S Copier
CANON GP405 ERROR E014 PROBLEM
sir i have ir 400 photocopir machin than problem is e803,e805 than coad plese give me soulison...............
Jan 06, 2012 | Canon imageRUNNER 400S Copier
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Jan 06, 2011 | Canon imageRUNNER 400S Copier
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
1,217 people viewed this question
old marine
old marine
