Question about Car Audio & Video
I think i blew my drivers side front door speaker. when i turn the balance to the left only the back door speaker works. every once in a while you can detect a loud crackling of "noise" from the left front door. i would like to replace both front door speaker. however i'm not sure how to remove the door panel. or does the speaker grill just pop out? if you can offer any info it would be greatly appreciated. thanks joe s.
  • joeyukon Jun 05, 2009
    very helpful
  • 10,515 Answers
You need to remove the Door Panel. Let me provide you certain links that would help you.
http://www.termpro.com/articles/doorspkr.html
http://prodactor.blogspot.com/2005/09/removing-door-panel-from-toyota.html
No matter, what's the model and make of the car would be, the above link would resemble as a guide to open the front panel and change the speakers.
Copy and paste the above links in the browser and press enter.
Any further help, let me know.
Thanks for using "Fixya".
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Jun 03, 2009
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
Nov 04, 2013 | Cars & Trucks
Why my front speakers don't work
is this a stock radio? i had a chevy radio that tone of the channels blew out and no front speakers. also check the door speakers to see if the wires aren't corroded from moisture .
Mar 27, 2013 | 2007 Chevrolet Cobalt Coupe
Stereo
pull the rubber boot back off the wiring harness in the crease of the drivers door and check for broken wires there. common problem due to the number of times these wires flex to allow the door to open and close
Sep 21, 2012 | 1996 Jeep Grand Cherokee
Car stereo speaker only works with volume turned way up
try the fade button, if its a 4 speaker system you have balance left and right, and fade front and rear.
Dec 21, 2011 | Clarion Car Audio & Video
Door chimes on my 2007 impala are low in sound.Any hints? thank you
Ok left side door speaker is the door chime speaker, I would check the left side door speaker to make sure it's not blown out. This can be done by using your fade & balance button on the radio and going to front speaker and left side only and to see if the speaker is blown. if so replaced it
May 28, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
My pass side door speaker quit orking I took the
check wires in the door hinge area should be in a black boot. Check balance setting on radio making sure it's not adjusted to left side and right
Dec 09, 2009 | 2002 Ford F150 Regular Cab
Radio works. volume problems on drivers side front speaker
It sounds like the problem is with the speaker, not with the radio
Dec 04, 2009 | Cell Phones
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
Only one speaker is working
i also have the same problem. in the begining both of the speakers were working now it's only one. it's not the balance setting either, i think i either blew something, but both of the speakers work when i switched the wires.
Apr 15, 2008 | Nakamichi SoundSpace 8 System
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
