Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Warm fridge, cold freezer
My refrigerator is warm(52 degrees) and the freezer is cold. The fan sounds like it is running in the back of the freezer, with frost along the back. Freezer setting is at 3 and refrigerator is at 5.....not sure what to look for.
  • bprejsmith Feb 21, 2009
    My freezer is -6, my refrigerator is 69.
  • Anonymous Mar 28, 2014
    Freezer at -22 degrees, refrigerator at 40 degrees. Runs all the time
I had the same problem. There was tons of ice build-up in the freezer back wall which prevented the cold air from flowing into the refrigerator section. I removed all the products from the freezer, and melted the ice - even took off the back panel (lots of ice back there). It solved the problem.
Posted on Feb 19, 2009
I had this same problem 2 years ago ... it was the board.
Posted on Jun 09, 2008
    Problem Solver:
  • 9 Answers
You may want to see the information at if you have the bottom freezer with French Doors. Sounds like your evaporator fan motor.
Posted on Jun 07, 2008
  • 248 Answers
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Posted on Nov 16, 2007
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
601 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
