Question about LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television
I replaced the lamp,was working fine,2 days later turned on the tv,and nothing just a blank screen..sounds works but no itcher??took the lamp back out an all seems fine there?
I replaced the lamp,was working fine,2 days later turned on the tv,an just a back screen...sound works but no pitcher???took the lamp back out,and all seems fine there?
  • trickaz_rock Jun 04, 2009
    err... colour wheel??whats that an how would i check it?also whats a cathode ray tube?? thanks
    Genius:
  • 1,239 Answers
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Posted on Jun 03, 2009
RCA 32 Smart Tv SLD32A30RQ Will turn but nothing happens and has a blank screen.
It sounds like the internal calendar function is working perfectly.
Nov 12, 2015 | RCA Televison & Video
Black screen on VOJ32o1A
Check and replace the back light inverter board. Check CCFL lamps too.
Jul 29, 2012 | Vizio VOJ320F1A 32 in. LCD TV
Our tv recently displayed projection lamp was about to go out and needed changed, so i purchased a new lamp assembly and replaced it. tv worked good as new for a few days, then in the middle of watching tv...
Most often, I find when servicing these televisions, the lamp has failed but it was due to poor fan circulation. This television has at least 3 if not 4 fans. If you take off the back and find these fans are filled with impacted dust, the fan may be causing the failure. Also check to be certain your door safety switch is making good contact. These tips should ber of assistance but check your fans. A clean inside of a tv is a happy tv!
Jul 11, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Tv restarts while we're watching it
It sounds lamp is weak in tv and need to be replaced.
If lamp has not been replaced in last 2-3 years then replace it to get tv problem fixed.
Thanks.
Jun 07, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
TV turns off/on
remove the bulb,(very easy to do just follow directions in the manual). On the top and bottom of the lamp there is a fine mesh screen. mine was plugged with dust. I used a vaccuum hose to remove the dirt, replaced the lamp and the tv now works.I found this remedy at a site but can't remember where (crs syndrome). saved me a $200 service call.
Jan 26, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Ok, the solution for all our problems is in fact the lamp. I finally replaced my lamp and no problems to report. Sony should do something about this because I know I didn't have 8,000 hours on the lamp and it sounds like no one else has either. I tell you what, I'm NEVER buying another Sony product ever again. Not only did I have this problem but I bought a Sony Blu-Ray disc dvd player and I've had nothing but problems out of it. I keep getting firmware updates for it but it doesn't help and recently I bought a Sony Walkman MP3 player and for no reason it quit working, it would power up and immediately power off. Sony did replace it though (but of course it was only $70 compared to the prices of the tv and dvd player).
Anyway, if you are still having problems with your tv, the lamp door is on the right side, pop it open and there will be another door with a knob on it. Turn that knob counter clockwise to unlock it and pull it out. Inside that door you will see the handle for the lamp, put your finger through the loop and pull up and out at the same time, to put in the new lamp, push lamp straight in until it won't go in any further and puch down, it should then be locked in place. Replace both inner door and outer door and you are good to go.
Someone mentioned something about cleaning the dust from around the lamp. I tried that before I got my new lamp. It only worked for a day and gave out again. Hope this helps.
Mar 02, 2008 | Televison & Video
Open Questions:
LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television Logo
397 people viewed this question
