Question about Epson Stylus CX5000 InkJet Photo Printer
To realign my cartridge carriage i need to press "ink button" cant find it epsoncx5500
I cant find ink button on cx5500 to replace ink cartridge am i stupid or what?
  • Epson Master
  • 511 Answers
Turn on printer, and just unplug power while carriage moving. Unplug USB. Then move carriage by hand.
Posted on Sep 15, 2009
I have new cartridge for my epsom 300 but cant remember how to get the old ones in position to be removed
Make sure the cd-dvd tray is up, press the little button next to the power button. then look on the screen on the printer and scroll down to replace ink press ok and it should move the carriage a little way to the left so you can open the carrier to replace inks , put ink cartridge in press ok.
Hope this helps
Aug 22, 2010 | Epson Stylus Photo R300 InkJet Printer
I want to replace the ink cartridge, let me be informed about the procedure to instal the new ink cartridge
Press ink button once, the carriage should move to ink replacement position. When in position replace the ink cartridge, after replacing the cartridge push the ink button once again.
Jan 17, 2010 | Epson Stylus C20SX InkJet Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
Ink change or epson cx5500
there is a water droplet icon, press that.
Jun 11, 2009 | Epson Stylus CX5000 InkJet Photo Printer
How do I replace an ink cartridge on NX400?
Assuming that that you have no errors preventing the cartridge change, press the "setup" button, use the arrow buttons to select "maintenance" and press the "OK" button. The carriage will now move to the replacement position. If you have an error condition and you need to access the ink carriage then swith on the printer and when the carriage begins to move across to the left simply pull out the power cable. The carriage can now be carefully pushed into position. Ensure that the carriage is pushed back to the right before turing power back on.
Hope this helps, please take a moment to rate this solution, thanks.
Apr 09, 2009 | Epson Stylus NX400 InkJet Printer
Where is the ink button on the epson stylus sx 200
Open the printer, Press the button below the power button (maint button) the carriage will move across to indicate which cartridge needs changing. Keep pressing until the carriage moves into the replacement position. After replacing the cart's make sure the lid "clicks" down fully and close the printer, then press the maint. button once more. The guides can be downloaded from Epson:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=YZnBT5wk60b3BgnyGPpyYp8WazlF4Pwn&tc=5#10
Please take a moment to rate my solution, thanks.
Apr 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Ink carriage
This is a tricky little printer. Here is your fix.
When you hold down the ink button for 3 seconds, the printer will perform a cleaning cycle.
But if you continue to hold the button for 10 to 15 seconds, it will then come ove to the opening where you can access the cartridges.
Apr 02, 2008 | Epson Stylus C44UX InkJet Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
225 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
