Question about Zebra Eltron P310I Thermal Card Printer
Eltron P310 Ribbon Issue.
I have a Eltron P310 Card Printer here, the ribbon keeps snapping in the middle under the printhead and wrapping around the roller at the bottom. Is there any reason this keeps doing this as its driving me crazy???
Thanks in advance
SOURCE: My Eltron P310 card printer pulls in the ribbon
My Eltron P310 card printer pulls in the ribbon alongwith the card, past the print head. Thanks for any advice
Posted on Oct 03, 2010
  • 54 Answers
SOURCE: printing special effects from corel draw on Eltron p310
Try looking for an option in printer driver Graphics settings which prohibits black panel printing
Posted on Nov 17, 2008
SOURCE: Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Posted on Apr 11, 2009
  • 254 Answers
SOURCE: My ribbon roller couldn't roll that suppose to be ...
Check that you are in thermal transfer mode and not in Direct thermal.
The motors are active only if you are in Thermal transfer
Posted on Aug 16, 2011
printertech1
  • 96 Answers
SOURCE: I replaced the ribbon in
There is a diagram that shows the correct route to thread the ribbon and media in the upper lid. All zebra ribbons come off the supply hub clockwise (left to right) and the ribbon only goes under one roller prior to the print head.
Posted on Aug 26, 2011
There are long axis print voids. Does the print head need to be replaced?
Before replacing your printhead, try cleaning the printer, run the cleaning card and also clean the printhead using the alcohol saturated swab, zebra part number 105909-169. In some cases that will fix your issue, if not your printhead needs to be replaced. If replacing your printhead, please make sure your card stock are clean and don't have sharp edges as that could be the cause for a scratched/burned pixel on the printhead.
-- The Pros at www.DiscountIDStore.com
Sep 22, 2011 | Zebra Eltron P310 Thermal Printer
Sep 08, 2010 | Zebra Eltron P310 Thermal Printer
Zebra p330i
lose the two screws from the front plate, put a card under the printhead, ajust the plate on tope of the card, tie the screws. send a command !SA from the driver, and print a test card (send IM command)
Jun 21, 2010 | Zebra Eltron P330i Card Printer
Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Jan 21, 2010 | Zebra Eltron P420C Printer
Keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Oct 15, 2009 | Zebra Eltron P330i Card Printer
What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work.
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Jul 08, 2009 | Zebra Eltron P310 Thermal Printer
I have Broken ribbon message on the LCD display. I just changed the ribbon and the clean cartridge. Hellp
It could be that the printhead is damaged or the ribbon sensor needs repair. Call Zebra troubleshooting for help. If it is under warranty you can send the printer back to zebra for repair. Takes about 3-5 days. All the info is on their website. good luck.
Jun 16, 2009 | Zebra Eltron P330i Card Printer
Printing special effects from corel draw on Eltron p310
Nov 15, 2008 | Zebra Eltron P310 Thermal Printer
Ribbon Breakage
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Regards
Jul 10, 2008 | Zebra Eltron P310I Thermal Card Printer
Bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
Zebra Eltron P310I Thermal Card Printer Logo
239 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
