Question about Cell Phones
Memory card access problem
When i plug my USB cable in my S40 mobile,it says "memory card is being used by another application"
    Sergeant:
  • 218 Answers
It could be used by messages storage
Posted on Jun 03, 2009
Nokia s40 nokia 2700
firstly install these applications from Nokia store....third party s/w might not work properly. install application with mmc inserted and use them with mmc inserted............Permissions like always allowed/ask first time are only for network (GPRS) access....Mobyexplorer requires net.........many free applications also require net access as they carry some ads....if these permissions are denied then application closes......but be sure....if u select always allow/ allow first time, data usage charges will be applicable
Mar 13, 2014 | Nokia 2700 Classic
How to unlock micro sd memory card, when i forgot my password
Recover an SD Card Password b> Secure Digital (or SD) memory cards are one of the most popular forms of digital media storage. When using SD cards with a mobile device, you can set a password to protect unauthorized users from viewing the files. However, sometimes, you may lose the SD card password. If you have access to the mobile device, recovering the password is a simple process. If the mobile device is not present, the only way to recover the password is to reformat the device.
Download and install a file explorer application, such as FExplorer, X-plore or Best Fileman onto the mobile device. http://download.cnet.com/f-explorer/3000-2094_4-75758737.html Run the application on the mobile device. Select the "Find" option. Type "MMCSTORE" in the space provided. Connect the mobile device to the computer via either a Bluetooth connection or the connection cable that came with the mobile device. Send the "MMCSTORE" file to the computer. Rename the "MMCSTORE" file "MMCSTORE.txt" on the computer. Open the "MMCSTORE.txt" file on the computer. Write down the password located in the "MMCSTORE.txt" file. b> Using a PC b> Download and install the SD Formatter program from the SD Association website. http://www.sdcard.org/consumers/formatter/ Insert the SD card into the computer's SD card reader. Run the SD Formatter application. Select the SD card from the drop-down menu and click the "Format" button. Formatting the SD card will reset the password. However, the process also will remove any data that is stored on the card. Allow several minutes for the SD card to format. Hope this helps.
Sep 14, 2011 | Kingston 2GB Secure Digital Memory Card
When i'm connecting with the USB cable,it is saying memory card is in use by another application,and thus not connecting.........why is it so?plzzzzz sort out this problem
Hi
Please make sure you are not using any application and that insall in Memory card, Check any start up application is running, close that all application and try again. otherwise restart your mobile.
May 20, 2011 | Nokia 7210
My mobile is nokia s40 series name is nokia 5130c-2 in my mobile i have 2gb memory card before 3 to 4 months i have entered a password in order to protect my memory card but at present i hav forgot it. i...
Im afraid you'll have to format your memory card plugging it into a computer unless you can still access it through your phone and backup your data first.
Mar 18, 2011 | SanDisk 2GB microSD Memory Card
My phone cannot access the memorycard.
There are so many cases when people can't access the memory of the SD memory card.When you get connect with your system then it may need the driver to recognize the connected device.
The mobile phone comes with a driver or suit any thing which is associated with the mobile phone during purchase.You can install the driver and easily get access to your mobile phone and card memory both.
Some of the mobile phones are not being detected without the proper driver.Samsung D780 drivers
You can access the memory of your card using the provided cable which can solve the problem.Just plug the cable into your phone and another end should be plugged with computer.
Wait for a while if it is not coming quick as you want.If the device is not being detected the you can use the device manager utility of the windows system.
Move to the My computer icon >Properties >Hardware tab> Device manager> .
Check your connected device in the list of Universal Bus Controller and if not find then move to the Control panel and use the Add new hardware wizard.
Another solution is:
Using Card Reader to access the files:
The memory can be accessed with one of the different methods but for this procedure you need to have another device called Card reader which is associated with a cable.
The memory can be accessed with this procedure :
1- Pull out the SD memory from mobile phone.
2- Use the card reader,insert the SD memory and plug this cable to computer.
3- Try to look, if the device is showing in the windows then it alright and your mobile phone has some disturbance regarding detection.
4- Just make the desired operation and if that is not being performed then you have to format the driver,I don't think any options is rest to try.
Oct 11, 2010 | Samsung D780 Cellular Phone
How store the movies and songs in the memory card and how to see the memory status
To transfer movies and songs in the memory card you can either insert your memory card into your phone and plug the USB cable that came with the phone into your computer. From the computer, you can drag and drop files into your memory card so that it can be played/viewed on your mobile.
Alternatively, you can use a memory card reader to plugin to your computer via USB port or use an inbuilt memory card reader on your computer to access the memory card. From there, you can drag and drop files onto your memory card. Just insert the memory card back into your phone when you are finished.
To check the memory status of your mobile phone go to where your files are and press Options, there should be a option for you to check your memory status. Or you can go to Tools, Settings, Utilities and look for Memory. This will tell you the memory status on your memory card.
Hope I have been of assistance to you,
Cheers :)
Apr 22, 2010 | Lands Phones
How do you format it on your computer?
You need card reader for access memory card or if you have mobile memory card then you can connect your mobile to computer with usb cable.
Or insert memory card into card reader and connect that card reader to computer with usb cable.
Then you can see your memory card in my computer as removable storage.
Then right click on it then click on format then choose FAT32 and quick format then it format your memory card.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 09, 2010 | SanDisk 8GB microSDHC Memory Card with...
Dont know where to plug in my mobile phone to get pictures from it
your mobile should come with wire that can be hook up in your pc. at the end of this wire/cable is a USB that you can hook up in any USB ports in your pc. also if your computer has the capability of bluetooth same as your mobile then by activating this features, you can easily access your photo from your mobile. goodluck
Oct 22, 2009 | Dell Dimension 8300 PC Desktop
Use my music from computer to phone
Do you want to transfer music from your computer to your mobile phone?
Connect the phone to the computer using the USB cable that came with your phone. Or transfer the file using bluetooth
Sep 17, 2009 | Dell Inspiron 1200 Notebook
How to install .jar files in samsung sgh d780
hey samsung mobiles have a typical problem with this java appliacationa installion. we need .jad file with .jar file both are to place din memory card.open the memory card and open the .jad file then it gives the option to instal.
ENJOY.................
Aug 12, 2009 | Samsung SGH-J600 Cellular Phone
Cell Phones Logo
67 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
