Question about Microsoft Wireless Laser Desktop 6000 V2 Keyboard/Mouse
Microsoft wireless laser keyboard 6000 v2 - keys suddenly stopped/not working
I replaced the batteries (I am typing this note from a different computer/same kind of keyboard) and reset button on the back, but I cannot "log on" as I need to type in a password...and keystrokes won't register even when I place the cursor directly to the area (NOTE: wireless mouse works fine!). Help. Kathy upstate,NY Wireless keyboard not working... When I take the batteries out of the keyboard and then put them back in, the green battery light on the keyboard glows for about 10 seconds and then fades to nothing! I've tried replacing batteries and pulling the keyboard apart but nothing seems to work????
dutchman05
  • 487 Answers
SOURCE: Microsoft Natural Wireless Laser Mouse 6000 doesn't work
Hi
If you take the batteries out there is a screw in there. unscrew and open (not easy) with flat knife in the edges wiggling.
attach and touch all the inside wires. I have had the same problem and it is an internal connector problem. Opening and closing aint easy and will take a little patience but it will work.
Good luck
Posted on May 03, 2008
SOURCE: microsoft wireless laser keyboard 6000 v2 - keys suddenly stopped/not working
i had the same problem, i checked the batteries with a DMM and the measured 1.4v i replaced the batteries with new and i still had the same problem. anyway i ended up taking the keyboard apart and found where the antenna is connected to a push on type connector alongside the pcb board inside the keyboard, the connection was slightly corroded. i cleaned it up and it is working fine know, even with the old batteries.
Posted on Sep 17, 2008
yooperbud
  • 8637 Answers
SOURCE: Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
Posted on Jan 16, 2009
SOURCE: Microsoft Wireless Laser Mouse and Keyboard Cut in and Out
I had the same problem wth the mouse. In desperation I moved the USB sender from the back of the PC to an unused USB port on my HP L1940T. Lo and behold, problem has gone away, but I suspect more by luck than judgement. David.
Posted on Apr 02, 2009
SOURCE: microsoft wireless laser keyboard 6000 v2.0 keyboard not working
You have to press the button on the receiver that is directly connected to the computer. While doing this, press the connect button both the mouse and the keyboard. I did this and now my keyboard is working, despite the battery indicator turning itself off a few seconds after I install it.
Hope this solves your problem.
Posted on May 04, 2009
My keyboard seems to type letters, especially x
Hmm, sounds like a electrical fault but it could be a virus so scan your computer just in case.
May 05, 2010 | Microsoft Wireless Laser Desktop 6000...
The enter key in the keypad area stopped working. All of the sudden when you press the key you get nothing.
Buy a replacement keyboard -- much cheaper than paying a technician to attempt to trouble-shoot.
Responsibly recycle the old keyboard.
Apr 26, 2010 | Microsoft Wireless Laser Desktop 6000...
Microsoft laser moues 6000 v2, doesn't work. it worked fine for like half a year... and then suddenly my computer "doesn't recognize" the transceiver piece...
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Sep 17, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Wireless desktop 6000 keyboard problem
Check the inside of the battery chamber to see if there is corosion on the spring or front pip for the + ve.Batteries leak ands should be chaged every 6 months regardless
Jul 27, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
Microsoft wireless notebook laser mouse 6000 not working
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still no workie. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the mouse's opening for the battery appeared to be bent down (away from the contact on the battery tray). So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Jun 26, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft wireless laser keyboard 6000 v2.0 keyboard not working
Mar 20, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft Wireless Laser Keyboard 6000 v2.0 enters wrong keys!!!
install the divers for the keyboard and the mouse. Do not activate the options (standard setup)
Feb 27, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft wireless laser keyboard 6000 v2.0 has locked up. how to unlock?
for the laser 6000 v2
hit the reset button on the wireless receiver (oval button)
THEN
hit the small white reset button on back of wireless keyboard (it's called Connect Channel)
presto!
Oct 08, 2008 | Microsoft Wireless Laser Mouse 6000 v2.0
Aug 07, 2008 | Computers & Internet
Microsoft Wireless Laser Desktop 6000 V2 Keyboard/Mouse Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
