Question about Coleman Powermate Powermate 5000W Generator
Need to replace fuel shut-off valve on Coleman Powermate Generator PMO525202. It has a 5 gallon plastic tank. How do I remove the original valve(without breaking something)? Thanks,
  • 98 Answers
Well..the whole valve has a place where u can place a 12 or 13 size spanner...and then just twist it..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
Where is the fuel shut off valve
Powermate generators usually have a shutoff mounted to the bottom of the fuel tank. There is a knob at the bottom of the connector where the hose is attached to the fuel tank. Screwing it in (clockwise) shuts off the fuel.
Aug 30, 2012 | Coleman Powermate Portable Generator...
My Coleman generator runs great for about 3-5 minutes then shuts down.
I am guessing this is caused by some type of floating debris in your tank. I think that unit might just have a simple grommet holding the outlet fitting into the bottom of the tank. Try removing the outlet fitting and try to make sure the tank and fitting are free from debris.
Aug 12, 2017 | Coleman Powermate Powermate 5000W...
Where do you buy the gas shut off valve for the 5000 power mate coleman generator with a 5 gal plastic tank.
Take the old valve, called a petcock, to a local lawn mower repair shop and they should be able to help you.
Jul 13, 2011 | Coleman Powermate Powermate 5000W...
Generator is leaking gasoline out through the carburator when not running. Also, fuel shutoff valve at bottom of gas tank will not shut off completely. What are probable causes and price to fix ??
Most often fuel leaking out the carb is caused by a needle and seat problem in the carburetor / the float level shaft screw may have come loose due to the vibration of the engine ,this will cause a leak issue with the needle and seat as well. To complete the repair the carb will have to be removed and cleaned. Replace the needle and seat if necessary an then replace the carb.
May 30, 2011 | Coleman Powermate Powermate 5000W...
Where is the fuel shut off valve on a coleman powermate 2500
follow fuel line from fuel tank to the carb if you dont find it it probably does not have one
Sep 04, 2010 | Coleman Powermate Proforce 2500 Generator
My Coleman Generator Model 19G412 has a fuel shut-off screw/valve. It was in the off position. I needed to use the generator, but when I tried to turn the screw/valve to the on position, it would not turn....
explore the possibility of removing & replacing the 'petcock'[fuel valve] in the tank.drain tank,remove gas line,unscrew petcock retaining nut at tank & replace.
Oct 12, 2009 | Coleman Powermate Powermate 5000W...
Fuel leaks from around the valve at the 5 gal plastic fuel tank
you twist the whole valve after disconnecting the hose...
get a new one and put it instead...
if u have any further questions let me know:
Jun 29, 2009 | Coleman Powermate Powermate 5000W...
How many gal tank is the Powermate 6250 10 KW
Nearly all of the Powermates have the same 5 gallon fuel tank.
I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
Carl
Dec 12, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
1,220 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
