Question about Whirlpool Washing Machines
Spining makes noise and machine vibrates a lot
My 6th sense 650h whirlpool washing machine makes loud noise while spining during wahing. it even vibrates. however whwn we use special cycle of 'tub clean' i.e. without clothes it spins smoothly. how much noise is normal? varsha
Its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Posted on Apr 09, 2014
  • Manohar
    Manohar Oct 10, 2015
    what is clamp for
All machines vibrate and make sound while spinning including front load. Dont worry, its perfectly fine
Posted on Sep 01, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
My whirlpool front load washing machine is making a loud knocking noise when in the spine cycle.
Bad tub baring or hopefully a cloged drain pump. If it is a tub baring it is going to cost a lot of money.
Good luck,
Marty
Jul 24, 2012 | Whirlpool WFW9550WW Duet Steam 4.4 cu. ft....
I have just bought a Whirlpool 6th sense 8kg load washer. It makes a clunking noise whilst washing and seems to be loud when spinning is this normal
have you been overloading the drum---thiscan put too much strain on the rear bearings---you willhave to replace the complete drum
Dec 07, 2010 | Whirlpool AWM6100 Front Load Washer
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Whirlpool 650H - Timer Problem
the timer unit will need to be changed, that happens on some of the brands,if my info was of any help to you please leave a comment ,thank you
Sep 01, 2009 | Washing Machines
Hi I have a Whirlpool 6th Sense Washing Machine - AWM8143. I is washing and spinning perfectly well and there are no error codes. However when it spins the machine makes a grating squeaking noise that is...
hi,
looks like there is some friction between the main and outer tub of your machine. there is generally a mechanism for smooth spinning of the machine in good rpms for wash-spin cycle. this could be because of rust formation, or mud collection. please refer your manual and remove the 3 screws behind the lower front plastic cover, and look for rust formation. scrape the rust and try spinning again.
cheers
Jul 26, 2009 | Washing Machines
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Not spining
sounds like the lid switch.
Mar 09, 2008 | Washing Machines
Washing Machines Logo
974 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
