Question about Sony Playstation 3 (PS3) Console
Ps3 only see lines and only can hear sound when i move controler?
When start up it start to come on and then all i get get is a few lines on the side on tv and can hear something when i move the contoler buttons.
    President:
  • 987 Answers
To solve this, when the ps3 is in standby (solid red light), just hold the power button. It should beep on, then beep again in about 5 seconds. This will automatically search for the optimal audio video output. if if beeps on then turns off, just try again, it takes 1 or 2 tries sometimes. the reason this is happening is because your ps3 is set to one AV output, ex. composite(red yellow white), HDMI, and then you changed the cable to a different one. another way to fix it is plug both cables, HDMI and composite, into the tv and ps3, then go to settings and change the output to the desired one.
Posted on Jun 03, 2009
I have a CECHA01 model (60 gb) PS3. Lightning recently messed a few things up which includes the PS3 (yes i was using a surge protector). Every time I start the system the fan gets really loud for 6-7...
Okay, hold the ps3's power button until it shuts off. Then hold it again until it beeps twice. When prompted, plug your controller in. Press the PS button on your controller. Now, dpad
Jul 20, 2011 | Sony Playstation 3 (PS3) Console
We have a PS3, a few years old, never had a problem. My son turned it on tonight and the initial "PS3" logo comes up with the wavy line and then thats it. Just keeps the wavy line there...
hello, turn the power on then press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset the ps3
fingers crossed it should work
regards
shaun
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
My PS3 has been broken for a very long period of time. About 6-9 months now, I've lost track. Every time I turn it on my PS3, it starts with the wavy animation and the colored background, and then the...
Ok, please try the following steps :
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep a total of 3 times and turn off again. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, then 5 seconds later it will beep again and then it will beep twice quickly. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this then continue to the next step
Step 5. The PS3 will load with a menu with 6 options, choose number 5 "Restore PS3 System" and follow the on screen prompts.
Using this method should sort your PS3 out for you.
Hope this helps
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will power up and there is some sound for a few seconds while starting, screen displays waves thats it
You need to restore file system on your ps3. If that do not work, restore ps3 system to format your hard drive.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Cant access the ps3
this is happened cuz ur PS3 is over heated u have to cool it and clean it, use the hair dryer to get the dust out of it and try to keep ur PS3 cool all the time, if it didnt work when u start ur PS3 keep holding ur finger over the bower button for 5-7 mints u will hear a double beep sound remove ur finger then ok u will see a menu with a few options in it choose the first one restart PS3 also if it didnt work do it all over again (the problem that i cant rem. what that menu contain :S ) but any way check if there is a repair PS3 option ok. or if u PS3 start normally by accident go directly to the settings menu and go down and choose repair PS3
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 startup fails
try removing the hard drive then booting it up then putting it back in and booting up again.
then try holding the power button while the ps3 is in standby (red light) till it beeps,... then beeps again,...then turns red again,....then let go and hold the power button again real fast you should hear beep....then a double beep beep. let go of button and you should see recovery console. choose rebuild file system. it will reboot and go through the rebuild steps. then if it still doesnt work go through the steps of recovery consol again and choose rebuild database.
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezes in the start
When turning on Press and hold your PS3 power button for about 6 seconds. You will hear 2 more bips!
This will reset your PS3 to MFG default. Connect your Composite jacks (Yellow, red, white) from your PS3 to your TV in order to hear and see the display! This will not delete any of your data!
GoodLuck!
Jun 26, 2009 | Sony Playstation 3 (PS3) Console
Bluetooth head set
listen to the sound,there is a disconnect beep,when i play i push the side button till i here a beep if u here 2 that means disconect if 1 beep connect.check to make sure it works.
Oct 15, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
