I installed a Lutron eco-dim 600 Watt dimmer on a single pole. Once installed the switch works in reverse (up is off and down is on). While I can just flip it and install it upside down, the dimmer also works in reverse. So when the light is on (and switch is in down position) and the dimmer is up, the light is af full brightness. I have tried switching the wires, and reinstalling with the switch in the off position, but nothing seems to work.
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
SOURCE: After instalation of 600w lutron
This, unfortuantely, is one of the usual challenges associated with dimming. The buzzing usually gets worse at around the 1/2 light level point. I don't think the issue has to do with whether the lamp is halogen, but rather how the lamp is physically constructed - and that differs from manufacturer to manufacturer. Long story short, I would take note of the lamps you purchased, and when replaced, I would opt for a different manufacturer.
SOURCE: Hello - I have just
Double check the model number - is it a TG-600PH or a TG-603PH?
If its a TG-603PH, and this is part of a 3-way circuit (there's another light switch that turns the lights those same lights on & off), then this is normal. If you flick the other light switch, you'll then see that the dimmer works like it should. This has always been the case with 3-way switches, up doesn't necessarily mean "on" and vice-versa.
If its a TG-603PH, and this is part of a single-pole circuit (this is the only light switch for those lights), then the product is miswired, and upside-down. To fix the miswire, look at the screws on the back of the unit (ignore the green grounding screw for the time being), two of those screws are made of the same material (same color), and only one of them should have an electrical wire going to it. Take that wire out and put it on the other screw of the same color. That fixes the miswire. Then when you re-install the device, flip it upside-down from what it was before.
If its DEFINATELY a single-pole, TG-600PH, then call their tech support center at 1-800-523-9466 - because that makes absolutely no sense.
SOURCE: New dimmer switch not working
Hi -
The Lutron D600P is a preset single pole dimmer. Wiring is pretty straight forward as show in this diagram. Recheck wiring and if OK, continue below.
If power is present on both wires (black / red wires), power is being passed through the switch to the lamp and the light should be on. If not, try replacing the lamp.
Minimum recommended connected load is 40 watts. This switch is ONLY for use with filament type lamps - such as traditional tungsten, halogen, etc. It is NOT to control speed of Fan Motors, nor dimming of CFL (compact fluorescent lamps) energy saving types or other ballast operated lamps such as High (or Low) Pressure Sodium, Metal Halide, Fluorescent, etc. as this would create a high heat condition and could cause a fire.
If you're still having trouble, you can contact Lutron Technical Support Center 1.800.523.9466 24 hrs / 7 days www.lutron.com
I hope this helps & good luck!
SOURCE: Lutron Dimmer switch, single pole, will not dim
We are truly sorry for your inconvenience and want to help. Please call our Technical Support line at 1-888-523-9466 and we'll be happy to discuss the issues with you.
Craig, Lutron Technical Support Leader
