Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Ge nautilus dishwasher dial is stuck How to reset or get dial to move?
  • chrisp1976 Jun 03, 2009
    Chech the soap door inside. If open, then close. Dial may move then.
  • 1462 Answers
SOURCE: GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
Posted on Apr 19, 2007
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Posted on Dec 28, 2007
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Posted on Jun 18, 2008
SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
Posted on Nov 11, 2008
GE Nautilus dishwasher doesnt drain
Water dosent drain Is there a reset button???
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus wont start
Looks like you need to replace the timer/cycle panel on your appliance.
Try first unplugging machine for 20 minutes, to see if this reset can fix the problem.
Aug 28, 2008 | GE Nautilus 24" Built-in Dishwasher
My GE Nautilus dishwasher stopped. Before it
Sounds like your door interlock switch is faulty.
There is a metal tab on the unit that triggers a interlock switch. The switch is located in the door and is part of the door handle. This tells the machine that the door is closed and that it is OK to start.
Most probably the first experience with the machine continuing to work with the door open was that the switch in the door was stuck in the on position. When you closed the door it moved to off and stuck there.
Open the door and use a screwdriver to move the switch to the on position. Move the timer to on. You should hear the unit start. If so it is the switch. Repair or replace it. You could try WD40 and switching it on and off a few times to free it up. Once you can see it is working make sure it is aligning with the tab correctly. You can bend the tab to adjust the alignment.
To repair:
Turn the breaker off.
There are screws on the frame of the door and in the door to hold the control panel in place. Carefully remove the control panel to access the switch. Once you see it you will be able to remove it easily as it just screws in. Replacement is the reverse of removal.
Hope this helps please rate if it does help you.
Mar 14, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap dispenser does not close
Make sure the dial is at the start positon and not in between on some other setting.
Sep 04, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher with stuck fan motor
Sorry about the delay, I have been gone this week. Yes, it sounds like it will need to be replaced. I will need the model and serial numbers for your appliance to tell you how much the part would cost. Let me know and I'll try and get back to you as soon as possible.
Jun 12, 2008 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS DISHWASHER
The pump motor may be stuck. If this is the case, as it often is with a GE dishwasher, you can break it loose (e.g. spin the impeller until it doesn't spring back any more). If it's not stuck, it may have something inside of the pump motor and it may need to be replaced.
Mar 25, 2008 | GE Nautilus 24" Built-in Dishwasher
Soap door latch won't latch close
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
119 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
