Question about Cameras
The display on my wifes Pentax optio E65 is impossible to see in bright sunlight. Is this a common problem with this camera or is there a fault on the camera?
  • t_nicholson Jun 03, 2009
    I don't think that this can be put down to a general problem. The Pentax camera is impossible to use in strong sunlight but my Cannon can be used without any problems in the same level of sunlight.
  • 13,433 Answers
The LCD display is most likely just too dim / the back light is set on too low or it has generally an dimmer display back light.
Look around the camera's settings and look for the LCD back light adjustment, try to adjust it, and when taking pictures, try to stand in a shadow so that you could at least make something out from the camera.
I suppose there are some hoods available that you could put on top of the back of the camera / on the LCD display so the sunlight wouldn't get to it as much.
if even after all those things the back light is still way too dark I would suggest to take the camera to a local dealer and have it checked and compare it to another model of the same brand or to another same camera if they happen to have one in the shop.
even if the camera is on warranty I don't think this goes under warranty, as I don't think its actually a problem that would require repair. Unless the back light goes out completely, then the company should replace it / repair it free, if its under the warranty.
you could even possibly think about a hood for the camera, do you remember those really old cameras? and the person taking the picture behind the camera had this black robe or something to that direction on that covered the back of the camera and he / she had to get under the robe to take the picture. maybe you could try something like that.
Just a suggestion, let me know how that goes.
Thanks,
Ekse
Posted on Jun 03, 2009
  • 10,594 Answers
It is normal as camera LCD can not show image in direct sunlight because sunlight is far brighter then LCD Back Light.
Thanks.
I bought pentax optio H90 after a couple of months that i have been used it accidentally get wet by my wife...i didnt know f my wife dried it up or not as i was not there...now the pics started to appear...
It is very difficult to know what you think is distorted, because it does not say what kind of distortion. I have to say sometimes people only give four words, so you are telling a lot.
But seeing one picture could say more than 1000 words.
You think you could post just one picture? or is it impossible to add pictures when you just start here in fixya? I can't remember.
Jan 19, 2014 | Pentax Optio S5i Digital Camera
How do i change battery pentax optio e65
Just do a web search, Type: pentax optio e65 user manual
You will be able to download a free copy of the manual.
Jan 22, 2013 | Pentax Optio Cameras
I need an English Pentax Optio E65 Manual
I can't find the Exact Model, but I found the E60 and they may be very similar or exactly the same, so here is the link to go download the manual http://www.pentax.jp/english/support/man-pdf/optio-e60.pdf hope this helps you!
Jun 13, 2012 | Cell Phones
Cannot take photos..... Screen shows no image
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the phone aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 29, 2011 | Pentax Optio 50 Digital Camera
Lcd screen is black when in bright sunlight,so camera usless in this situation.The rest af the time appears ok! Any ideas which may solve this problem?
Do you mean that you can't see what's on the screen in bright sunlight? This is common on 90% of the point and shoot cameras. Only 10% have brightness controls for the lcd.
Dec 03, 2010 | Pentax Optio A10 Digital Camera
Camera cannot display imageon pentax optio s12
The LCD screen could be broken, this is the most common problem. You can replace it yourself, or have a camera shop do it. Get an estimate first, if you decide to have it repaired, it's often better just to buy a new camera.
Mar 23, 2010 | Cameras
Pentax Optio M10 manual
Hi - You can download the manual from the link underlined in blue below:
Pentax Optio M10
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 24, 2008 | Pentax Optio M20 Digital Camera
Dark LCD screen
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jan 11, 2008 | Pentax Optio W30 Digital Camera
Optio SV - Date/Time problem
I think it is pretty obvious that your camera isn't going into full 12 hour mode and is displaying a combination of 12 hour (am/pm) and the usual 24 hour time. This could not come from anything other than a firmware error, and will be common to all SV's with the same firmware version. Almost certainly Pentax will fix it with a firmware update within the next few weeks to a month once they know about the problem. So you've proved that the problem is in the review mode in the camera. Is it also embedded in the date for the file and in the EXIF information included in the file? I guess that if 24 hour time works, the temporary fix might be just to use 24 hour time.
Sep 08, 2005 | Pentax Optio SV Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
