Question about Bosch 1600H-LP Liquid Propane AquaStar AquaStar Liquid Propane Tankless Water Heater
Raypak heater service code RV1
Raypak (model P-266A) pool heater gives temperature reading and indicates "off", the code RV1. Also, the control panel will not accept changes; i.e. I cannot change temperature etc. Panel occasionaly counts down from "38" showing all of the different service codes.
3 Suggested Answers
  • 234 Answers
SOURCE: Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
Posted on Mar 16, 2009
  • 16 Answers
SOURCE: Raypak 2100 has SNS error code. How do I replace control panel?
This is definately not a do it yourself project.
Posted on Jul 10, 2009
I discovered Whirlpool hot water heater was displaying E02 error code. Followed directions in manual to possibly correct problem, but E02 code continued to be displayed. What is the remedy for this?
Error E02 indicates that the water temperature exceeded high limit.
Switch off the house circuit breakers dedicated to the water heater and then press the reset button located behind the control panel on the water heater.
Switch house circuit breakers back on.
If error persists, call a service engineer.
good luck
Jan 05, 2018 | Whirlpool Water Heaters
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
Control on whirlpool EEZ8OHD055V Blinks twice, no hot water
1) Call Whirlpool. 1-877-817-6750
Have them send 2 new thermistors (temperature sensors located above each element), and then install according to the instructions they give you.
2) Sounds like you have the American brand older energy-smart electric water heater with grey control box on top
Copy following link to exactly identify product and resources
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html#energy-old
3) Two flashes is 'high water temperature shut down.
Buy cheap multimeter from hardware store. Install battery. Set to read ohm, the upside down horseshoe symbol.
Use multimeter set to read ohms, and test thermistors
Copy following link for general service manual showing error #2 and thermistor resistance chart on page 10
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 07, 2012 | Water Heaters
We just bought a house with an AquaStar II solar pool heater, when we try to adjust the temperature we get a flashing check sensor error. Can anybody help us find the sensors or how to fix it?
On the Goldline controllers, the check sensor light flashing means the sensor on the roof is either bad, disconnected or shorted out. When the check sensor light is solid on, that indicates it is the pool sensor. Check the wiring from the controller to the sensor on the roof. If the wiring is not damaged, most likely you will need to replace the sensor. You can check the sensor with an ohmeter, it should register 10,000 ohms at 77 degrees.
Oct 02, 2011 | Water Heaters
I have a AO Smith GPS 75 200. The power is on, however the temp control does not light up and nothing is working. Is the White Roger thermostat gas valve shot, is there some test I could do to make sure...
You have AO Smith tank-type power vent water heater with FVIR flame arrestor.
1) I believe this system has White Rodgers intellivent gas valve, with led indicator lights.
To test if valve is operational:
-NORMAL operating mode displays no lights on gas valve.
-Unplug unit from electrical outlet and plug back in. All lights on gas control should display for 1-5 seconds.
-Press BOTH Hotter and Colder temperature buttons for one second to 'wake up' the control, and release buttons and LED will display temperature.
-Press Hotter or Colder and see if any indicator light shows on gas valve.
This will give baseline if gas valve is functioning.
-Intellivent gas valve requires outlet that is wired 100% correctly. Test outlet with circuit analyzer.
-Water heater must be properly grounded for intellivent to operate.
2) Open following link to identify gas valve and download possible service manual with error codes and testing procedure. Service manual is a large file and will probably not load on dial-up.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
3) Open following link for AO Smith manuals and service handbooks.
Shows same intellivent service manual, and shows manuals for power vent, but does not specifically list the GPS75 series
http://www.hotwater.com/resources/product-literature/service-handbooks/
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 08, 2011 | Water Heaters
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
Jul 18, 2011 | Water Heaters
The control unit needs to be reset when I loose power
have two boilers one a rheem the other raypak, the raypak keeps turing off i have to push the reset button. what could be wrong
Dec 30, 2009 | Rheem Paloma Tankless Water Heaters...
Bosch 1600H-LP Liquid Propane AquaStar AquaStar Liquid Propane Tankless Water Heater Logo
304 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
