Question about Everex StepNote NC1502 Notebook
The computer starts up but the screen is black
The screen will not start up did what "myjosh007 said to do, i have similar problem, i turn on the notebook and the hard drive/cddrive lght flashes once then goes away then flashes a second time (i believe the second flash is for cd drive) but still a blank screen, and i know its not the hard drive, i put it in another computer that supports serial ata and works fine in it. could something such as the serial ports be fried?
  • Luis Perez
    Luis Perez May 11, 2010
    do you know if it is a problem with the LCD ? did you try connecting an external monitor to it ?
Iinstaled win xp, now monitor will not work. can i download and install driver onto flash drive without seeing my monitor
Turn your notebook off.
Turn your notebook on, and immediately start pressing the F8 key, once or twice per second,
until you see the Windows "start-up" menu (white text over a black background).
Choose the "start in VGA (low-resolution") mode" (or some wording similar to that).
You computer will start-up in '800-by-600-by-256-colours' mode, which should work.
Adjust the screen-resolution, and the number of colours to "optimal" values.
Jan 31, 2011 | KDS Valiant 6480iPTD Notebook
Laptop has black screen on startup. what do i do to repair this.
I have a similar problem:
I have a Compaq Presario SR2010NX desktop computer. Recently, very occasionally, the computer would freeze and the screen would scramble. It almost looks like someone chopped up the picture on the screen. Then we would have to manually shut down the computer and restart. It would always work fine afterwards.
Yesterday the computer did it again. It restarted fine but when my boyfriend tried to install a new mouse the computer froze again and the screen went scrambled. Well this time it did not start back up. I tried to unplug the computer from the wall and restart but that got me to the COMPAQ screen and then the computer froze again and the word compaq was doubled all the way down the screen. We continued to try to start it in PC recovery but it would get the the program and freeze. I actually got it to run once but I couldn't see what it was doing because the screen was scrambled.
Now we have restarted it so many times that it will start up, light turns green, and stays green. The computer sounds like its starting up and it seems louder than normal. The computer doesn't do anything and the screen is black. The lights on the keyboard do not turn on but the light in the mouse does. The CD drive will light up and run as well but nothing happens after that. I can't see the cursor and the keyboard does not work.
I opened the computer up, cleaned the dust off, tried to re-install my old RAM and that did not work either. I disconnected the CD drive but that did not work. Tried to start the computer with nothing plugged in except mouse, keyboard and monitor and that did not work.
I don't know what to do! Help!
Oct 21, 2010 | Computers & Internet
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
My Compaq presario f572us notebook screen turns black upon normal startup. The screen does not turn black if I start-up in the safe mode. It only when i attempt to start windows normally. Everything loads...
i also have a compaq presario f572us that's been having similar problems. when i went onto the hp website i saw that apparently they've been having similar problems with this type of computer as they offer free repairs for 2 years after you bought it. you should probably check if this works for you too
Oct 23, 2009 | Compaq Presario F572US Notebook PC
Black screen problem
Friend, the LCD connections is broken especially the lcd interface or your LCD is broken and needs to be replace.thats the only problem no other parts 100% sure
Jun 26, 2009 | LG Shine CU720 Cellular Phone
My toshiba m35x-s111 laptop screen goes blank
According to the description of the fault and the symptoms that your equipment presents, you must replace the FL inverter, that is the one that gives the turn on of the screen of your equipment, if your you replace this piece that one finds behind of the mask of the screen in the low part and that is similar to a pen I assure you that your equipment it was working in perfect conditions
Dec 23, 2008 | Toshiba Satellite M35X-S111 Notebook
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
173v flat lcd black screen
I've had a similar problem with my 173v monitor since I bought it a few years ago. When I start my computer, Mac or PC (I've connected it to both), the screen remains black and the green power light flickers once a second, almost like it's twitching - it's different from the blink it makes when the computer isn't turned on but the monitor is. Like kronem, I have to unplug the line from the monitor to the computer, wait for the monitor to register no input, and then plug the monitor in again before it displays anything. I've never figured out a way around the problem - I hate it!
Feb 21, 2008 | Samsung SyncMaster 173V 17" Flat Panel LCD...
Everex StepNote NC1502 Notebook Logo
101 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
