Question about HP Computers & Internet
Startup does not complete
PC on startup reaches screen which says at bottom "verifying dmi pool data" then repeats back to previous screen which starts with "Vanta Bios". After turning pc off and on same screen at startup and repeats same two screens. Any advice gratefully received
    Genius:
  • 2,785 Answers
Plz check the website http://www.duxcw.com/faq/computer/dmi.html
Posted on Jun 03, 2009
Verifying DMI Pool Data..... please help
also depending on the operating system, you may have to insert Operating System DVD and boot and select "Boot Repair" or "Startup Repair"
Mar 26, 2015 | Panasonic Computers & Internet
Computers comes on and it goes to verifying dmi pool data and comes back with error msg....or after its been unplug for awhile it goes back to normal but after awhile it freezes up and then when hard reset...
During the verifying dmi pool data stage of boot, the Motherboard is trying to 'poll' the devices in your PC. This is governed by the BIOS settings in the CMOS chip. It is possible to have a defective CMOS chip, but rare. It is possible to have invalid or corrupted BIOS data in the CMOS chip--which can be cleared to a 'default' state. You stated that if it is unplugged for a time, that it will 'go back to normal', the corruption is being reset. If your BIOS is set to be 'shadowed into memory' for faster loading, then Disable that feature and see if the problem is corrected.
You would need to open the Tower and locate the Motherboard Model (like P5SD2-VM) then look on the internet for the Manual for that model and see if there are any BIOS settings for the 'shadowing' of the BIOS.
This problem can also occur if there are SATA drives in the Tower and 1 or more are not being detected, (depending on the BIOS MFR,) this happens to older boards with SATA ports, much more than late model ones; so while you have that side-panel off, remove and re-connect all of your Power and Data cables to the Hard drives and the Optical drives, (CD/DVD.)
Jul 31, 2011 | Acer Aspire AM1610-U1201A PC Desktop
Wont start up grey screen with warning verifying dmi pool data on my desktop pc which is acer aspire
well varifying DMI pool data is not a warning its a process where your system hangs. install new windows or repair the old one.
Jan 07, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
Hangs during boot. Last entry on screen is "Verifying DMI Pool Data........" Then blinking cursor at bottom of screen
restart the machine in Safe Mode. And restore to a back date. Alternatively, at boot time press F8 and select When OS booted correctly or some such option, meaning that when your PC booted correctly the last time.
Aug 07, 2009 | Northgate (STAX2517C2) PC Desktop
Acer desktop T180 is stuck on verifying DMI pool DATA..
verifying DMI( Data Migration Information/or Dynamic Migration Information) pool data refers to hard disk function. check the hard drive to see if it functioning properly.
Jul 12, 2009 | Acer Aspire T310 PC Desktop
Acer Aspire AM3100-U3202A ''hard drive'' will not boot up
That could be a hardware failure of some sort, or because you added a new hardware device. The "DMI pool" code has nothing to do with Windows, but is part of Plug and Play. Windows has not even loaded yet. It is the System Board BIOS startup code checking the hardware configuration, and setting system board resources for Plug and Play to use. Go in to the system board BIOS (normally DEL key when first powering on) Look in the PnP or PCI Configuration section, for an entry "Reset Configuration Data. It will show Disabled. Change it to Enabled, and save the new configuration and reboot. BIOS will set it back to Disable after it clears the DMI data and rebuilds it. The first time through, it will take a long time, but after that it should not hang. Unless there is a hardware problem with one of the adapters on the system board or PCI bus.
I have seen CD-Rom drives cause this hang, if there is a CD in the drive. So make sure there are no CD's in the drives when you start up.
Apr 01, 2009 | Acer Computers & Internet
Computer says something about verifying pool data
If it says something along the lines of verifying dmi pool data then you might have a problem with your BIOS ( the setup utility you refer to ). Here is a URL that describes a solution to this problem, it is pretty intense if you don't have at least above average computer skills - http://www.duxcw.com/faq/computer/dmi.html. Let me know if you need any further assistance with this.
Serge C.
Mar 30, 2009 | Acer Aspire T180 PC Desktop
Cant boot pc
hi i have put together a pc but when i power it up it say soft menue has changed and then says verifying dmi pool data pls can anyone help thanks
Sep 04, 2008 | Intel Motherboard
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
Computers & Internet Logo
128 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
