Question about Toshiba Satellite A15-S127 Notebook
Mp3 file correction
Few mp3 files in my pc are having some additional sound in it like live streaming of beep some have broken voices but i can also listen to the original voice also but in very low volume. these files were perfect earlier. this problem occurs all of a sudden.. pls help.. thnnx
I had recorded voice in PHILIPS (SAXX )which have been stored int the Recordings Library. But when i want to hear, i find a reply the " file format not supported". What to do to hear the voice...
If you connect your player to the PC and select your device in Windows Explorer you should find a "Voice" folder that contains your recordings. The files are named as voicexxx.wav and you can simply copy and paste them to the PC.
If you have problem with this and want to get additional help please define the exact type of your player because almost all the types of gogear are SAxx .
Thanks
gylacz
Apr 29, 2011 | Audio Players & Recorders
Files will not transfer to PC or play when attached to PC
Hi have you installed the correct software for your device
Dec 06, 2007 | Olympus WS-100 Digital Voice Recorder
Tip
Sharing Media Videos via DLNA-Connect the Converted HD Videos MP4 to Droid X via...
DLNA for HD Videos Streaming:Camcorder Videos to Droid X with Compatible Format <br />Droid X DLNA-Stream Camcorder HD Videos from Windows 7 PC to Droid X,WD TV Live Hub via DLNA <br /><br />I have recently setup DLNA between my Windows 7 PC and Droid X, and my other home devices like WD TV Live Hub. With HDMI cable connected between WD TV Live Hub to my HDTV, I can stream most of my videos from Windows 7 PC and watch on HDTV. But Droid X does not read the .mts files that I transferred to PC from my Sony Handycam CX700. <br /><br />Actually, there are DLNA-certified cameras, which might be easily connected to Droid X via WiFi. But my camcorder is the non-DLNA compliant Sony CX700, thus I need to store the .mts files on Windows 7 PC. The mts videos play well via <b><a href="http://www.aunsoft.com/final-mate/">DLNA streaming from PC to WD TV Live Hub with HDTV</a></b>. I was recommended to convert the camcorder videos in .mts to .mp4 for streaming to Droid X with Aunsoft Final Mate. <br /><br />Aunsoft Final Mate works great for the CX700 videos. I just need to import videos to Final Mate, create a movie for conversion from the File menu (File &gt; Create A Movie For Conversion), bring the clips to Movies tab. Click the Export button under the volume settings, and choose Droid X output profile to start conversion. You can also <b><a href="http://www.aunsoft.com/final-mate/">Free Download Final Mate</a></b> with the trial version, and give it a try. <br /> <br />For those who may have problem <b>Setting up <a href="http://1080p-converter.com/2011/07/sharing-media-videos-via-dlna-connect-the-converted-hd-videos-mp4-to-droid-x-via-dlna/">DLNA Video Streaming</a></b>, here I would like to give you the fast guide with my Windows 7 PC, WD TV Live Hub and Droid X. <br /><br />1. Windows 7 PC is DLNA-compliant, and I just need to activate two services: SSDP Discovery and Windows Media Player Network Sharing Service. <br /><br />2. Make sure the devices are in the same network, and put the video files to the video folder on Windows 7 for sharing. <br /><br />3. WD TV Live Hub and Motorola Droid X are also DLNA-compliant. There is built-in DLNA application on Droid X, and is available in the Application tray. Just run DLNA to control or play videos on Droid X. <br /><br />Below is the DLNA application on Droid X: <br /> <br />Turn on WiFi, and you will face the following screen for playing media, copying media to server, copying media to phone, or share media. <br /> <br />To stream and play the MP4 files converted from AVCHD files by Final Mate, just choose Play media, and Droid X will ask you to choose source, choose player, and start streaming. <br /><br />With Final Mate, you can easily stream <b><a href="http://canon-videoconverter.com/2011/07/droid-x-dlna-stream-camcorder-hd-videos-from-windows-7-pc-to-droid-xwd-tv-live-hub-via-dlna/">Camcorder Videos to Droid X with DLNA Compatible Format</a></b>. Hope you enjoy it.
on Jul 07, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
How do you delete a recorded voice file? I have selected the files but only a beep sounds when I hilight a selected file and then tap the menu button.
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you
do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
May 10, 2010 | Samsung YP-T10 Digital Media Player
Softwere for DS-330
DSS Player (version 7.0): http://www.olympusamerica.com/files/DSSPlayer.zip After unzipping the file, click on the SETUP.EXE file to begin installation. License key: 8360 0121 0002 6901 5480
Jun 08, 2009 | Olympus DS-330 Digital Voice Recorder
I am having problems playing back downloaded files.
Are the files actually .mp3 format? There are a few different compressed formats available now and some mp3 players etc are not compatible with these formats.
Older players (and some current ones) for instance will not play .wma files which are Windows Media Audio files.
Feb 02, 2009 | Electronics - Others
I need to copy digital voice recordings to cd
you will need to change the format of the files by using sound recorder in windows xp. just open the file and save as cd quality format. this will change the bit rate to 16 bit needed to make a cd
Jan 17, 2009 | Olympus VN-3100PC Digital Voice Recorder
IHP120 20gb multicodecjukebox-voice recording
Sir,
I solved the problem .Actually under the SOURCE title it was under the LINE IN.There were some more options like INT.MIKE, EXT.MIKE, OPTICAL. So i first tried under external mike by connecting to the EXT.mike and selected the source and by removing the external mike switched to Int. mike and changed the source. It automatically picked according to the source and played the recording and saved it in the file and later heard the lecture with the head phone and later converted in to a file in the laptop. Now it is working nicely. A really a good product to make use and it is very much user friendly.
Thanks again.
regards
crsrinivasan
Aug 02, 2008 | iRiver iHP-120 MP3 Player
RCA's RP5120 Digital Recorder has VOC format, can't share or copy to CD
Version 4.04 of the software has a utility to convert to .VOC files to .WAV or even .EXE. (Are there really folks who would prefer to receive an .EXE file in email?)
I've read in several reviews that you can save .VOC files as .MP3 files using the provided software, but either this feature is no longer available, or the reviewers were mistaken.
You can convert .WAV files to .MP3 files simply. You may find one such converter for free on C|NET at:
http://www.download.com/WAV-to-MP3-Encoder/3000-2140_4-10060500.html
A 5 minute google search (wav to mp3 freeware) revealed 3 absolutely free utilities which will do this. I, too, wish mp3 support was native with this product, but I can live with using these utilities.
Jul 06, 2008 | RCA RP5010 Digital Voice Recorder
Toshiba Satellite A15-S127 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
