-   Sir, Our Scanner is not working with windows XP please provide us upgraded driver with Win xp configuration. regard milind-   sneham
Mar 08, 2008
-   Sir,
regard m.khalid42-   mkhalid42
Nov 30, 2007
-   ScanPrisa640P Acer not working with winXP need drive-   Guest
Nov 29, 2007
-   my scanner 640p not work with win xp-   khono
I need a hendheld pen scan
suitable for XP and editable on word,
to save especially half of the...
(More)
to save especially half of the lines not the all page,also it should write-
I need wireless one,with large memory,which can run on batteries I can recharge on the USB port.
do ou reccommend anything please?
I m going to use it in Europe
on Bugarian and Turkish
thanks a lot
I launch Image zone then select the scanner device, then click preview scan. A message window pops...
(More)
I launch Image zone then select the scanner device, then click preview scan. A message window pops up: "cannot initialize scanner" HP Scanner preferences
I've double checked the electrical and USB connections; also the Lock Switch. I've uninstalled and...
(More)
I've double checked the electrical and USB connections; also the Lock Switch. I've uninstalled and reinstalled the scangear toolbox. When I try to run the copy or fax function, I get the following error messages: (1) "Unable to open TWAIN source Please check connection Then re-start Toolbox" (2) "Unlock the Lock Switch and turn the scanner on again. Scanner driver will be closed." I've tried everything I can think of but I'm not technologically savvy.
With my HP Deskjet 4100 I am able to scan thru my laptop but when I try to scan to desktop that is...
(More)
With my HP Deskjet 4100 I am able to scan thru my laptop but when I try to scan to desktop that is networked with laptop thru wired router will not let me scan. If I connect 4100 directly to desktop will let me scan. How can I get it so both computers are able to use scanner without having to disconnect and move the scanner. Both computers print fine to the 4100
