Question about HP Computers & Internet
HP Optical Disk Drive Problem but no error reported!!
I have an HP combined DVD-RW/CD-ROM (came with the system - an HP DC7900 cmt) and it appears not to be reading disks. If I put a disk into the unit, the green light on the front comes on and you hear some noise but nothing comes up on the screen and after a while the noise stops and the light goes off.
In File Explorer, it shows Drive E as a DVD-RAM disk but, even if there is a disk in the machine, it does not show any content.
I have checked the driver and even deleted it via Device Manager so that it is automatically restored on restart. The device manager reports it as working normally. However, when looking at System Information, it shows no details in respect of the unit.
I have also checked the cabling and this appears to be plugged in correctly.
Any ideas as to what the problem could be?
  • mark_claydon Jun 03, 2009
    Brilliant.... I was hoping that this was not the case but if its broke then not much choice. Will probably replace it with the same model since this should be the easiest way of doing a swap.
    Thanks for the advice - it is appreciated.
    Genius:
  • 2,785 Answers
Its seems you need new optical drive
Posted on Jun 03, 2009
Dvd+rw nd-2100ad no disk in drive error
Can you see DVD-RW drives indicator busy when you insert that disk for a long time? if so, your drive may not going to read that disk. If it is in case of CD disk, sometimes DVD-RW just can't read it while very old CD-ROM can read! If this happens in case of other CD/DVD witch is readable by other DVD-RW, You may just try to clean the lens of your drive.
Jun 29, 2012 | HP Pavilion a620n (PC028A) PC Desktop
HELP MY COMPUTER WONT READ ANY CD'S EXCEPT A DVD,, WHAT IS THE PROBLEM?? ANY HELP
hi
you have either one of these ..
5187-5619 = DVD-ROM/CD-RW combination drive - 48X CD-R write, 32X CD-RW rewrite, 48X CD-ROM read, 16X DVD-ROM read
EL436-69001 = 48X DVD-ROM CD-R/RW optical drive - 48X read, 32X read, 48X read, 16X max write speed
make sure you buy CDs or DVDs which are speed compatible to your optical drive or COMBO drive speeds
if you are busying compatible speed CD media, then take some compressed air (can) and clean the drive bay and inside the optical drive area, to dedust it .
go to this site and review all the related sites .. read carefully and try to figure out what the possibility (issue) is .
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=15887&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=431075
if ALL this fails, you may have to replace the DRIVE itself
i hope this helps
Nov 08, 2010 | HP Pavilion a705w PC Desktop
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
Aug 01, 2010 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
It won't see a blank disk or write to it
CD-ROM and DVD-ROM. ROM stands for "Read Only Memory". On the other hand, CD-RW, DVD-RW stand for "Read/Write". So, if the specs of your laptop say that you only have a DVD-ROM, not COMBO or something ending in RW, then you laptop's optical drive is simply not built for writing to discs.
Feb 15, 2010 | Sony Computers & Internet
Sony DVD+/-RW |DW-Q30A will not record cd or dvd & only play dvds
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD , or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Mar 28, 2009 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
When i try to copy dvd it keeps telling me to insert blank disc even though one is in there i can burn cds but not dvd it tells me to put in writeable disk and ive put in dvdr-w and dvd-r and still it...
Go to the device manager to insure your optical drive is in fact a DVD/RW. You should also be able to tell by looking at the front of the drive and see what it says. If it says CD Writable or DVD Rom, you cannot do it. Kind of sounds like you have a CD/RW-DVD Rom combination drive, which does not allow the burning of DVD's.
Let me know, OK.
Mar 15, 2009 | Dell Inspiron 1501 Notebook
Dics Drive Upgrade for Toshiba Satillate.
As far as i know thats impossible. Your optical diskdrive is made just for those speeds that you have on it. You cant change the manufacture settings and speed it upp, or make it to an dual layer disk.
Buy a new one whit the needs that u want and replace the old one. Its easy done and its not that expensive.
Good luck to you
Nic
Feb 04, 2009 | Toshiba Satellite A105 Notebook
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Worldvet
Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Computers & Internet Logo
80 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
