Question about Toshiba e-Studio 232 Black and White Copier
Setup photocopier wirelessly
Hi Toshiba E Studio 232, change settings on drawer paper size from A4 to A3, also setup instructions to link to a laptop, have no manual.
  • Toshiba Master
  • 643 Answers
To change paper size setting, press the user function-->user-->drawer. In order to do network printing using network port (RJ45), u need to make sure printing kit (GM107x) is installed on your machine. It looks like an thumb driver. But u can also enable the 60 days trial periods in order to try out the network printing.
Posted on Jun 03, 2009
I need help wth a Toshiba e studio 181 it refuses to pick up A3 paper nd wen it does it jams?
make sure drawer is set for a3 if not push user interface button then drawer and set the drawer for that size and be sure you actually have a3 size paper this is not a common size of US paper
Jun 07, 2017 | Toshiba Office Equipment & Supplies
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
How can I change the paper size( from A3 to A4) without changing the drawer
on the drawer you need to set the paper wide sensor ( blue handle ) must be on A4, also you need to put back rails and stopper in A4 position.
Hope that helps!
Jun 09, 2011 | Canon imageRUNNER 2000 Copier
Ttrying to print from A4 to A3 but it keeps ttelling me to change draw to correct paper size even after i did it
Have you made sure you changed the drawer size setting on the copier as well as the physical size of the drawer?
Aug 19, 2010 | Toshiba estudio 255 Copier
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
E-Studio 3511 will not print a3
check to make sure on the display panel the paper tray is showing A3 PAPER SIZE>> the paper size indication should match up to what is in the trays if not the machine will be asking for A3. Also try putting in another tray to see if there is a fault with the paper tray .. if it works with other paper sizes it may just be the size hasnt been set properly for that tray.. Hope this helps A
Jan 18, 2010 | Toshiba E-Studio 3511 Color Copier
My e-Studio 3500c copier has 4 paper drawers, and one is set as LD (supposedly), but when we try to print to that drawer, it changes the paper size to 8-1/2x11 instead of legal size. We had a tech come in...
Once u setup the drawer paper size, make sure u tick the update automatically on the printer driver properties. Otherwise the printer driver wouldn't detect the correct paper size.
Dec 28, 2009 | Toshiba E-Studio 3511 Color Copier
Keeps saying add paper but paper is in legal and letter drawer
Check the display carefully, is it waiting for a different size to be supplied, or is it waiting for apaper to be loaded into the bypass tray
If you attempt to print/copy to a size not loaded into the machine, they will wait for the requested size. (depending on your optional menu settings)
This is especially a problem if you eg. try to print A4 size, and only have US legal or US letter loaded into the machine, and visa-versa.
Dec 09, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 Black and White Copier Logo
349 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
