Question about ASUS K8V-MX Motherboard
Bios problem bios errorinsert start up diskpress enter
  • 1,226 Answers
Re: bios problem
Please try replace a computer CMOS battery and boot computer in to your CD Utilites enclosed in the system. Or download and install the bios updates in the
and try to repair manual on updating bios. the guideline on updating bios is here:
If not solve the problems maybe u can replace your bios.
Posted on Jan 07, 2008
0 characters
3 Points
How to enter bios Gigabyte EP45-DS3L
when you start the computer use the (start pressing )the delete key on the keyboard to enter bios.
Aug 17, 2014 | Motherboards
Power but no display
try going into bios blue screen press f2 or f10 or f12 on start up beep . change setting in video settings
  1. Watch for a "entering setup" message in the first few seconds after turning on your computer. This message varies greatly from computer to computer and also includes the key or keys you need to press to enter BIOS.
    Here are some common ways you might see this BIOS access message:
    • Press [key] to enter setup
    • Setup: [key]
    • Enter BIOS by pressing [key]
    • Press [key] to enter BIOS setup
    • Press [key] to access BIOS
    • Press [key] to access system configuration
  2. Quickly press the key or keys instructed by the previous message to get into BIOS
Oct 22, 2013 | Biostar Motherboards
Need to access the menu
Know what the ->enter BIOS Setup key is?
It's on the bottom of the computer manufacturer logo screen.
Got it?
Now press the CTRL and ALT and DELete keys at the same time.
Restarts the computer.
JUST AS SOON AS IT STARTS, start tapping on the enter BIOS Setup key.
Tap in 2 seconds intervals.
If you hear beeps ignore it. These are Stuck Key Error Code beeps, and it is you that is making them.
Still No?
Turn the computer off by holding the Power On button in, for 10 seconds.
WAIT 20 seconds, then press the Power On button.
AS SOON AS YOU PRESS the Power On button, start tapping on the enter BIOS Setup key. The rest is above.
[The time period to enter BIOS Setup goes by F-A-S-T!
As soon as you see the computer manufacturer 'splash screen', (Logo screen), it may be TOO late. The above method makes sure you get in BIOS Setup ]
Nov 21, 2012 | Motherboards
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Motherboards
Cannot use usb keyboard and even in the bios setup.
cannot acces to bios, cleared the bios
how did you do this if the keyboard was not working ?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 06, 2012 | Intel Motherboards
Chassis was opened
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
if this fails to fix the problem
Restart your computer during the boot up process you will see a certain key to press to enter set up (BIOS) Press and hold that key to enter BIOS
Enter Bios
Go to Inter grated Peripherals
Go to Onboard I/O setup
Find "Chassis Opened warning"
Set to "Disable"
Press F10 to save and exit changes
.Hope this helps you
Oct 20, 2011 | Gigabyte GA-G31M-ES2L Motherboard
I got an MS 7390 and lately I updated to the latest BIOS version which is 1.20. I normally use a USB keyboard but when I start up the computer it asks me to press DEL to enter setup. The problem is that...
Hello download a manual here at MSI:
You need to unzip the file when downloaded.
I guess the bios upgrade set the usb function off
You have to enter the bios and set it on again.
Look in the manual how you do that.
You need a PDF reader to read content.
Good luck
Jan 03, 2011 | MSI K8N Neo4-F Motherboard
My mobo pv4mm2 the onboard vga have problems it does not work. how can i entering bios set up for changing in video agp? actually i have a black screen.I can't enter into set up bios.
normally entering bios can be done in 2 ways
1.when u power on ur pc by pressing the power button, immediately start tapping f2 key continuously for some models some models we need to keep tapping f12->then go to system setup
Sep 16, 2010 | EliteGroup P4VMM2 Motherboard
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Aug 26, 2010 | Intel Motherboard
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
ASUS K8V-MX Motherboard Logo
274 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
