Try putting a drop of laquer thinner, just very little drop on your joystick and wiggle you joystick for a minute... if nothing happens, have your joystick replaced...
There are two possible likely problems here: the joystick "key" or contact on the printed circuit board is bad/worn or the joystick is defective. The "key" is the rubber button pad that you press to turn the PWC on and off. This keypad is carbon embedded rubber that makes contact on the printed circuit board underneath. When these age or get moisture, the contact on the board oxidizes and the rubber becomes de-carbonized resulting in a poor contact when the key is depressed. Cleaning the contact with rubbing alcohol and a light scraping tool works sometimes. Replacing the keypad is a must.
If these don't work then you have a bad circuit board in the joystick. Either replace the joystick or the PCB within it. PCB replacement must be done by a properly trained electronic tech or Curtiss\PG Drives who makes the joystick.
Yes u can go radio selection nd Divert calls using keypad witout joystick. First select any number on ur keypad, nd select more on right key, next use no2 on ur keypad nd select # key. here it wil display ur settings.. then select key no4. get list of settings.. then select no1 for call divert . again select no1 for divert always.. This s for divert calls.
For rado select any number on r keypad, nd select more on right key, next use no2 on ur keypad nd select no9 for radio.
just replace the keypad or if you are mechanically inclined remove joystick take the top off and glue a small piece of foil to the bottom of the on/off button reassemble and try that if that doesn't fix it order a new pad from a provider in your area
There are two board on 3230 first main board(engine) 2nd front board that contains camera,display(LCD) ,joy stick,keypad menu, etc.So to fix the problem are change your front board.Good luck.
there is a problem with your keypad board flex, the connections towards joystick maybe disconnected or damaged I suggest that you refer it to service personel for keypad board flex replacement, tested and proven..goodluck
