The head popped off of my trimmer. I don't know how the spring is lined up on the cutting blade!
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
SOURCE: Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
SOURCE: pop up trimmer stopped working
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
SOURCE: can i get another battery for the remington mb-35
you will find replcement batteries at shaveroutlet.com
SOURCE: Where can I buy a replacement battery for my
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
