Question about LG KG800 Cellular Phone
No lights in the touchpad when slide up
Hi guys,
My phone used to lit up when slide open and make slide open music but suddenly it has stopped doing both. If i slide nothing happens & the screen stays blank until i press mp3 or any side buttons. Pls guys help me.
Thanx in advance
  • sakabir Oct 24, 2007
    hey thanx a lot for that, sure i am gonna check that out.... thanx again
  • 425 Answers
Its probably the sensors inside your phone. most manufacturer uses magnet or sensing... if you can open your phone check if its still in place... if not visit your service center...
Posted on Oct 24, 2007
My touchpad seems to have competely stopped on my thinkpad edge. I turned it on and all of a sudden it wouldn't work, so i had to use the small red button above the touchpad. I checked on the cont
Hi
This could be one of several problems. The first thing to do is to make sure that the driver for the touchpad has not become corrupted. Sounds complicated I know but its not. Please follow the steps below and let me know if this solves the issue. I'm assuming you are running Windows 7 but it very similar in XP as well.
1. click on start
2. In the search box type device manager then hit return
This will open Device Manager
3 click on the little arrow next to Mice and other pointing devices
Your touch pad should be listed here.
4. Double click your device
its property box will open
5. click on the driver tab at the top
6. click on update driver (you must be connected to the internet)
7. follow the instructions and make the choise to search for the driver automatically.
This will download the latest driver for your PC and should fix thye problem. Please let me know the results.
Apr 09, 2013 | IBM Lenovo ThinkPad Edge 15 Notebook
My LG KU5900 touchscreen suddenly stopped working
hi guys my lg ku 5900 suddenly stop working all of its touch... do you know how to fix it or any shop you know for the replacement nof the touch screen.. thanks
Nov 28, 2012 | Cell Phones
Unlock touchpad Problems hp 4430S
Hi waris,
on you touchpad there is a light on the upper left of the touchpad tap it three time it should enable the touchpad for you and the light will be turned OFF meaning that the touchpad is active if the light it lit then it is inactive.
Feb 17, 2012 | Computers & Internet
So, whe i open (slide) the phone and touch anything on the touchpad the phone just shuts off. However, when the phone is not open and i just unlock the touchpad i can use the touchpad options without the...
Hi, My friend there is a loose connectivity issue... Please take your mobile to the service center. They will fix it for free if your mobile is in warranty period!
Please vote if you think this solution might help others:) and also feel free to ask me for more help... Thank you:)
Dec 04, 2010 | Samsung Trance SCH-u490 Cell Phone
Hi, I have a Dell Inspirion 1545 notebook. Recently my touchpad/hot keys will not display on my screen any longer. It's weird it just suddenly stopped. My hot keys (i.e. volume control, brightness) work...
the wire that attaches the panel to the system board has likely pulled loose from the slot. its a very thin flat cable and has no grips on it, it slides into a tiny slot. Its possible that Dell can walk you through fixing it, but if your machine is under warranty, I'd suggest getting a tech to come out and do it for you. it takes about an hour to get it back to par.
Nov 18, 2009 | Dell F3534 Touchpad
My Nokia 2680 Slider Phone suddenly stopped playing music
It won't be easy to fix it yourself but you could send it in if it's a really important feature for you. Otherwise you could try checking your phone regularly or just use ringtones
Sep 22, 2009 | Nokia 2680 Slide Cell Phone
My LG Chocolate phone is in mute and I cannot get it out of it. Cannot hear any sound out of earpiece...can only use if it is in speaker phone mode...have I changed the setting somehow....is there a way to...
Not sure if this will help you, but when you slide the phone open, do you see 4 red lit-up indicators surrounding your center data wheel? On mine there are:
Red line - top left
Red line - top right
SPK - bottom left
CLR - bottom right
(Note that the indicators stay lit for about 20 seconds)
The indicator at the top left is the MUTE On/Off switch (you will see "MUTE" in the main display, just above the top left indicator). Although there is no real 'switch' there, you just push on that red indicator. It should vibrate when you turn MUTE on or off.
If the indicators go dark, the switch stops working. In that case, you have to slide the LOCK switch (this is a real switch, on the right side of the phone...it's the middle thing - above the MUSIC switch and below the micro SD opening). Just slide downwards and let go...the indicators should light back up, and you can use the MUTE switch then.
Hope this helps.
And BTW, the reason I am answering this question is because despite all I've just explained, my Chocolate MUTE swith, and all those indicator switches, have recently become intermittent. Which means when I am on an important call, after I switch to MUTE I find I can't get it out of MUTE. So if you try the above and it doesn't work, maybe your phone has a problem like mine....
Jul 07, 2008 | Cell Phones
Laptop won't boot
Try booting in safe mode, then clear out all cookies, cache and temp files.
Hope that helps!
Dec 19, 2007 | Packard Bell Easy One Silver 2101 Notebook
LG KG800 touchpad locked
As a default setting on the KG800, the phone automatically locks due to its touch screen sensitivity. If it doesn't work with the slide closed, try opening it, going into Settings, then Security, then touchpad lock, and set it on off. If that doesn't work, I'm out of ideas. Sorry. It's a great phone with nice features and all, but I've gotta tell you, I'm getting pretty sick of all its problems. If there's anything else I can attempt to help you with, my email is: Bittersweetindulgences@gmail.com Good luck!
Sep 10, 2007 | LG KG800 Cellular Phone
LG KG800 Cellular Phone Logo
78 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
