Question about HTC S710 Smartphone
Could not open the setting function
I could not open the setting function of my mobile. while i try to set any thing like ring tone, alram, theames and so on.. the message is appear like this your system could not open the file
  • 421 Answers
Which is your phone and model
Posted on Jun 03, 2009
Nokia 2730 - not getting ring tone with some incoming calls. Message left that I have missed a call
If you are facing the problem with some incoming calls it is an indication that you have set different ring tones for different users or incoming calls.
Very simply reset your mobile to a default setting by going to setting, restore factory setting and every thing shall be back to normal.
Oct 24, 2012 | Nokia 2730 Cell Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
Wallpapers and ring tones and theams or not set even restart the mobile
hi
then there must be software problem in your mobile just format your phone and try it now. this will fix your problem.
thank you
Dec 22, 2010 | Sony Ericsson Walkman W205 Cell Phone
Where do I find ringer settings for OT-880A Alcatel phone?
In settings for determinating the various functions of the phone, such as ringing tones for messages, E-mail, ringing tones. One of the options in most phones vibrationration.
If you go slowly through all the functions in your phone,you are bound to find "phone settings"
Jun 19, 2010 | Cell Phones
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
I have nokia 6600 but he is not showing miss calls and message tone is also not ringing why
hi,the absence of the missed call could be a factory fault or a virus attack.then the message tone that is not ringing,tryb to see if the message alert was set on your mobile,if this was set then i advice you take your mobile to a mobile engineer for internet flashing because it could be a virus attack.thanks.
Mar 08, 2010 | Nokia 6600
Ringar is not working plis help
ok first you need to check to see if your phone plays any tones at all .
if so you most likely have your ringer turned off. go to menu then settings then sounds. in sounds select ring tone or ring volume.
you will need to check in this area of your phone. select a tone and check to see if your ringer is off.
if that is not the problem you may want to try a soft reset. this will reset your phone to factory settings.
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Nov 14, 2009 | Nokia 3220
Cant hear messages coming thru on my ericsson mobile although in my settings it says it does. No ringtone.
Try this first,
but you'll need to back up all your data to your removable memory card first.
remove the sim card and the memory card, power up your phone,
GO to Menu
then TOOLs or Setting
the Master reset (default security code is 0000 or 00000 unless you changed it
then after the setting completed try your phone..
now if ever it does'nt work then you''ll need a technician to check your BUZZER not the speaker but the BUZZER, it is the same as the speacker but it's main function is for ypour tones(ex. alert tones, ringing tones, music and etc)
Nov 02, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sony ericsson w890i
I took my phone into my local carphone warehouse and they sent it off to sony ericsson for free!
First of all they accidently replaced the microphone as the description the woman in the shop provided them was unclear.
However, they were very apologetic in the shop and sent it off again.
It works perfectly fine now, and only took around a week.
Tip: make sure you provide a very detailed description of what is wrong with the phone and check that it it working when you get it back before you leave the shop!
Oct 06, 2008 | Cell Phones
HTC S710 Smartphone Logo
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
