Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
No power turn on my computer after 5 months of being away from, the power comes on but the picture does not , checked all connections and all seems well, I have had this computer for at least 5 years,!
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 07, 2008
Sony kdl60ex640 no picture has sound
The backlight inverterer section circuit might have damaged. Get it repaired by the authorized service center, as it is in warranty period.
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Apr 02, 2013 | Sony KDL Televison & Video
Color gets hazy & basically is only pink & green
try to open the unit.then check for anything suspicious, like connectors if properly connected etc.then , power it on.look for something that causes the fan to stop running or anything related to that.check the lamp, too.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The monitor turns off and on repeatedly.
Is it desktop or laptop computer?
If its desktop the data cable might be loose on the back of the desktop computer.
Apr 26, 2009 | Acer Computers & Internet
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
No picture
hello
Seems to me that your power supply has weak 330 or 470 Mfd 200 volt capacitors.
Use computer grade Caps
I would have them changed first.
Thanks Guy9
May 07, 2008 | LG 42LB1DRA 42 in. LCD Television
50 inch insignia plasma
THIS BRAND OF TV IS NOT REALLY RELIABLE AS IT IS ECONOMICAL YOU SEEM TO HAVE A POWER SUPPLY PROBLEM MOST LIKELY A POWER CONTROL BOARD ISSUE .
IT WILL BE MORE ECONOMICAL TO PURCHASE A BETTER BRAND NAME TV AS THE INSIGNIA BRAND PRODUCT IS ECONOMICAL PARTS ARENT AVAILABLE.
Feb 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Vertical lines
Get some freeze spray from radio shack then try placing a little spray on each chip on the video board and power supply board and each time you spray a chip look for the picture to clear up. When the lines go away you have located the bad IC.
Jul 09, 2007 | JVC HD-70G886 70" Rear Projection HDTV
Picture shows up for about 3 seconds then the screen goes black
XEROX 19" (XG92D) 5 MONTHS OLD...IT GOES TO WHITE WHEN WINDOWS TELLS IT TO TRUN OFF AFTER 2 HRS...IT GETS HARDER TO COME ON EACH TIME IT IS TURNED OFF. I TOLD WINDOWS TO NEVER TURN IT OFF. IF THE POWER GOES OFF I MUST TURNED IT OFF AND ON MANY TIMES, THEN IT COMES ON. I THINK IT MAY NOT COME ON NEXT TIME...
Sep 26, 2006 | Xerox XG-91D 19" LCD Monitor
Computers & Internet Logo
35 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
