Question about Samsung HLR5667W 56" Rear Projection HDTV
Picture is in 3d and green red blue
I have a samsung 56" and the screen is bowed and the picture is showing 3 of everything all in green red, and blue. Is this an economical fix that I can do myself or do I need to just scrap the tv and buy a new one?
  • Samsung Master
  • 5,138 Answers
Replace Both of your convergence ICs They are big black chips will have STK# on them also in same circuit there will be two low ohm resistors that might be bad 2.7 ohms CK them .
Posted on Jun 03, 2009
Picture like watching 3d movie. and bowing on side
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | RCA P56950 56" Rear Projection Television
Double picture,shadowing red
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 07, 2011 | JVC AV-56WP74 56" Rear Projection...
Bowed red green lines at top screen. picture looks like it in 3d.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 28, 2011 | RCA HD52W59 HDTV Projection Television
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
56" sony rear projection picture problem
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Feb 12, 2010 | Sony KP-57WS500 57" Rear Projection...
My red color on the color convergence does not match the blue and green color
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-56WP74 56" Rear Projection...
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Out of focus
•Screen looks 3D
Mar 06, 2009 | Toshiba 56HM66 56" Projection HDTV
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
150 people viewed this question
Jerry Greenberg
Jerry Greenberg
