Question about Ricoh Aficio 1085 Laser Printer
Entry into service mode
I have forgotton the service entry code for my Ricoh 1085, all i need to do is purge the toner through.. nothing else!
used to have it written down, then moved and lost the darn code!
  • 162 Answers
2-226 Toner Bank Toner Discharge
This SP removes toner from the toner bank
to the toner hopper.
After turning the toner supply motor and the
toner bank motor on, the toner supply coil
clutch turns on and off at 2 second
intervals. The motors and clutch stop when
the toner near-end sensor (in the toner
bank unit) detects no toner.
Even if the sensor continues to detect
toner, this operation stops when the clutch
has been turned on and off 10 times, so
this SP may have to be repeated to clean
out the system completely.
good luck...
Posted on Sep 10, 2009
  • bcxprint Jul 14, 2011
    thanks for the info.. do we have to clear the code from the service mode after xclearing the toner?
    Problem Solver:
  • 6 Answers
I need to Know what you mean by purge you toner, The Service mode is use for trained tachnical reps only and if you have had access to this mode you could do more harm than good. the toner ager system of this machine will through a SC592 code if you turn on the Coil and drive to move toner through it unless you kow what you are doing.So a little more info may help me help you.
Posted on Jun 06, 2009
Ricoh Aficio 2852 copier is having depleted toner error after adding new toner
Clear modes- 107 -hold down C button machine will enter service mode, in case it does not, open the right side door and front door then give it a try, it will enter service mode,but the fact is that for a depleted toner error you don't have to fight so hard, don't tamper the SP mode settings you are likely to land into some other problem & things will get complicated further. Install a genuine Ricoh toner and replace the developer along with cleaning of the TD sensor if a non Ricoh or compatible toner has been used previously.
Jun 24, 2014 | Ricoh Aficio Mp 2852 B&w Copier
Sc495 code
normaly its the toner bank sensors if you have replaced thet check the waste toner clutch if you cant solve it that way vacuum all the toner pipes in some casses they are blocked
Sep 15, 2010 | Ricoh Aficio 1085 Laser Printer
Ricoh aficio 1085 sc 547
Thie is a fuser error code enter service mode to reset. -Carl
Jun 09, 2010 | Ricoh Office Equipment & Supplies
While I am running richo aficio 1085 Pcl, It stops and show the code sc550. I try to switch the machine turn on and turn off alot of time but the result is the same, How can I do to remove this problem?
Oil Supply/Cleaning Web End. Change this and
Press the following keys in sequence.
Total Clear key 1 0 7 and clear stop for more of 3 second to enter to service program mode, eter to 1902 - 1... and change the value to 0%.
shut down the machine and turn on.
Jun 30, 2009 | Ricoh Aficio 1085 Laser Printer
Error 592....
Hello sir; The error code you display, means the toner motor defect, just replace it, will take care your problem.
May 27, 2009 | Ricoh Aficio 1085 Laser Printer
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh service code 502 - 520 - 496
You need to reset the bottle code. Clear/modes, 1,0,7, press and hold clear button. enter copy sp. select drum(#2) scroll to 2972, enter 0 and press # key. Do the same for 2973. exit all the way out, and recycle power.
Feb 19, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh Aficio 1085 Laser Printer Logo
351 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
