Question about Nortel BAP 120 (NT5S40CEE6)
Unable to acces the ap with some network cards
I am unable to access the nortel access point with some older and new laptops when iam trying to configure my dell laptop PP29L N series with BAP 120 , wireless is not detecting we tried all methode but failed can you suggest me how to do this ?
    Scholar:
  • 100 Answers
Can your laptor detect any other networks? If not make sure that your wireless switch is turned on.
If wireless switch is turned on and laptop detects other networks then your router is set not to transmit ssid (check router manual on how to configure SSID transmission mode).
Posted on Jun 03, 2009
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
Wirless connection wont connect to network.
On the WLAN world, exist a encryption key for connection. You will be able to see the "antenna", but until you enter the key you will not be able to access the network or the internet. First, disable the wireless security and try. Once you have verified the connection to internet then you add security. Use WEP.
Jul 06, 2009 | NetGear WG602 802.11g/b Wireless Access...
I might advise you to reconfigure the access point, maybe it lose the connection from before, reconfiguring the access point will going to have the previous performance.
Oct 29, 2008 | Nortel BAP 120 (NT5S40CEE6)
Unable to get connected to Belkin f5d6130 AP
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address 192.168.2.2
Subnet Mask 255.255.255.0
Default Gateway 19*2.168.2.1
DNS Server 192.168.2.1
Reboot
Post back results. Good luck and kind regards.
Oct 12, 2007 | Belkin (F5D6130) 802.11b Wireless Access...
Intel 2915AB Connection problem
Intermittent disconnection issues on a radio/wireless network will generally be caused by interferance (speakers, power board fully loaded, High wattage Lamp (flourescent bulbs usually) all parked too close to the wireless router, access point or network card. or possibly due to interuption of the active signal possibly because the distance of the router and network card/access point is just on the edge of the best signal limit and disruption occurs when someone or something gets up and moves itself inbetween the two service points)I resolved my disconnection issues by purchasing a wireless Kite for the access point and router, which will intensify the radio signal and bring the access points within closer range of each other, friends of mine have resolved intermittent signal issues by making a thin tube of rolled tinfoil about 30cm long slipped over each aerial affected by the intermittent signal disconnection. Also verify the "line of sight and non line of sight" signal distance limits for your radio equipment as the signal distance will decrease depending on the age of your wireless equipment, most equipment is in the 30Ft non line of sight- 100Ft line of sight arena out of the box but you can expect to half this figure after 3 - 5 years of continued use. Basically three options Interferance, Interupption or age only distance testing will verify this accurately IE: bring the router and access point withing 1Ft of each other and start walking away still holding the access point, whilst a user monitors the radio network condition.
Aug 04, 2006 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Nortel BAP 120 (NT5S40CEE6) Logo
205 people viewed this question
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
