Question about Quartet gbc GBC 10-Sheet Cross-Cut Shredmaster 2260X Shredder
DISCONNECTED WIRE I have a gbc shredmaster cc185 that I had to take apart to remove a metal jamb. I fixed the jamb but now I pulled a brown wire loose from the wirring harness. The brown wire is attached to the circuit board center mounted above the slide switch. What connector does this wire go to (color/color and where do they go to). Thanks frankrossii@comcast.net Frank Ross
I clipped all the zip ties to free up the harness and physically inspected every connector till I found a connector that seemed rather loose and came off with minimal force. I then gathered the 3 wires and install a #18 wiring nut. the shredder is fully functional again.
Posted on Jun 04, 2009
Tip
Fix / Repair Lay Z Spa Heater
1) Opening the shell and identifying the heater unit (its at the end of the metal pipe) You will have to unscrew the circuit board2_bing.gif and metal pipe to access the unit.
2) In the heater unit there are live (x2) neutral and earth wires.
3) The first live wire you need to identify is the one coming from the mains. It will be going into a water flow switch covered by a white cap. The wire is only clipped in, so pull on it with some force to remove it.
4) Next you should remove the other brown wire from the clips, so that you have a small section of brown live wire no longer attached to the clips. This piece of wire is no longer needed, but keep it in a safe place for if you need to reverse the process if this does not work (it should)
5) Now attach the original brown live wire that came from the mains into the clip which you just removed the small brown wire from. (not the part that was going into the white cap)
6) This should bypass the water flow switch and should allow the filament to heat. 7) Then reassemble the pod the way you disassembled it and the water should now heat up when attached to the spa.
on Jun 12, 2010 | Pool & Spa
Gbc shredmaster 5550x: this machine has badly worn plastic gears & one has teeth missing. Is a rebuilt drive unit available?
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now.
FixYa.com is not a parts or repair depot.
Thanks for your question today at FixYa.com
Jan 27, 2011 | Quartet gbc Shredmaster 5550X Confetti-Cut...
My electric door locks keep unlocking and even if they are unlocked they keep trying to unlock
Well, something is broken, somewhere. Start by removing batteries from remote key fobs, ALL of them, then pull apart each lock control switch, testing after each one is disconnected...the the ares of suspect is wires going through the door jambs. Starting with the drivers door.
If you find wiring damaged at the door jamb, you must replace the wire, rather than repair, so that there is NEW wire completely through the jamb area, anything else fails really fast, due to the flexing... At least cut damaged wire inside the door and inside the vehicle at kick panel...
Sep 25, 2009 | 1988 Chevrolet C1500
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Motor hums will not turn but will turn by hand
Could be as simple as a loose wire on the main board or surrounding electrical. Could be the start capacitor.
Sep 30, 2008 | Quartet gbc Shredmaster 6550X...
Quartet gbc GBC 10-Sheet Cross-Cut Shredmaster 2260X Shredder Logo
529 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
