Question about Acer Aspire 5920-6727 Notebook
DVD DRIVE F:/ NOT DETECTED IN MY COMPUTOR AND THERE IS EXCLAMATION MARK IN DEVICE MANAGER
DVD Ram GSA T20N not being detected. There is exclamation mark in device manager
  • 700 Answers
Install the driver first. Or update driver.
Posted on Jun 03, 2009
Restore dvd
Check the CD/DVD drives status in Device Manager.
  1. Click the Start button. In the Start Search dialog box, type dev, then click Device Manager.
  2. Locate the lDE ATA/ATAPI controllers. Click on the entry to expand the list and make sure there is not a down arrow in front of a device. If a device has a down arrow in front of it, right-click on the device, then click Enable.
  3. Make sure there is not an exclamation mark (yellow splat) on the device. If a device has an exclamation mark, right-click on the device, uninstall and reinstall the driver.
  4. Locate the CD/DVD-ROM drives. Click on the entry to expand the list and make sure there is not a down arrow in front of a drive. If a drive has a down arrow in front of it, right-click on the device, then click Enable.
  5. Make sure there is not an exclamation mark (yellow splat) on the device. If a device has an exclamation mark, right-click on the device, uninstall and reinstall the driver.
  6. Optical drive not detected
  7. Check BIOS setup to verify if drive is detected outside of Windows.
    1. Press the F2 key repeatedly as the computer starts.
    2. Locate the page where drives are displayed. This varies between different motherboards. Please reference your User's Guide for specific model information.
    3. Desktop computers: Refer to the Drive Configuration page (or similarly named page), or the Standard CMOS features page to identify all Optical drives that have been detected. BIOS Setup will present a table which matches drive ports (drive connectors on the motherboard) to drives detected at a given port. Example pages are linked. Reference the Product pages for the specific model.
      Notebook computers: Refer to the Main page of the BIOS to identify optical drives that have been detected. BIOS setup matches a Drive Port name to a drive detected at that port. Drive Port names (left side) vary per the following examples:
      > IDE Primary/Master: [HL-DT-ST DVDRAM GSA-T20N-] Left-Bay PATA: PHILLIPS CD-RW/DVD-ROM-(PM) Optical Drive: Optiarc DVD RW AD-7560A -(PM) DVD and CD drive names (right side) will include "CD" or "DVD" in the name.
    4. Inspect and reseat cables. Use proper Electrostatic Discharge procedures.
      1. Turn off computer and unplug power cord.
      2. Disconnect everything except the monitor and keyboard.
      3. Place computer on a stable work area with case cover facing up.
      4. Remove cover.
      5. Find internal drives.
      6. Inspect and reseat any cables to drives not detected. Click here for additional information about drives, motherboard connectors, and drive cables.
        • Check for broken connectors on drive, motherboard, and drive cables.
        • Check for bent or broken pins on drive, motherboard, and drive cables.
        • Check cable orientation.
        • If available, try a different cable. If drive works with new cable, the original cable is probably defective.
Dec 17, 2013 | Gateway MT6707 Notebook PC
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
DVD wont recognise disc
If your DVD drive don't show up in device manager and if there's no yellow exclamation mark in device manager, try to check IDE or SATA cable connection from your DVD drive to the motherboard. Also check the cable itself (are the wires inside broken?)
Feb 01, 2010 | LG GSA 4163B DVD±RW Dual Layer Burner
HL-DT-STDVDRAM GSA T20N it's not find DVD
Please try the following:
Go to device manager and uninstal the HLDT drive from DVD/CD ROM option.
2.Uninstall the secondary IDE controllers from the device manager.
3.Go to run iption and type regedit and press enter.
registry editer will be opened there expand H_Key_ Local Machine key and go to system>cureent control set>contro>class> single click on first key starting with 4D.
If on the right hand pane there is any lower or uppwer filters then delete them.
Restart the machine twice and check if not working you might need to change the ODD.
Thnaks.
Dec 28, 2009 | ASUS Eee PC 900 PC Notebook
HL-DT-ST DVDRAM GSA-T20N IS MISSING OR CORRUPTED ( CODE 39)
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the registor editor
7) Go Device manager right click on Computer (Vista) -go to properties left hadside Device manager
click the + on the CD DVD drive you will find the you find the exclamation mark right uninstall that driver and Reboot your system and the issue was resolve .
May 18, 2009 | Acer Computers & Internet
Amilo PA 2548: DVDRW GSA-T20N can't write discs
Go into device manager and delete that disk drive and then reboot and it should reinstall it. That will separate the drivers and put the old one back.
Jun 10, 2017 | LG GSA-T20N DVD±RW Dual Layer Burner
My HL-DT-SL DVDRAM GSA-T20N ATA Device zas not work & not fined
David is right, the easiest thing to try is deleting the device and having Windows reinstall at startup.
Nov 18, 2008 | Computers & Internet
After installing vista service pack 1 my dvd rom is gone.
Download the latest driver for dvd rom from Acer that will work with Vista SP1. Also try uninstalling the device in device manager and restart your computer. Vista may find "new hardware" and install the driver from its driver pack in SP1.
Jul 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5920-6727 Notebook Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
