Question about Panasonic Toughbook 19 Laptop Convertible Tablet
Reset bios HOW TO MAKE IT BOOT UP FROM CD
    President:
  • 1,179 Answers
In your bios you will need to change your boot sequense order to list the cd/dvd drive first. Save & Exit & your computer will be able to boot from the cd. Hope this helps.
Posted on Jun 03, 2009
My bios has a password need to unlock
Download and burn Hiren Boot CD, put it in the computer you need to remove the password. Hopefully BIOS is already set to boot to disc first.
Run BIOS Cracker.
This video was ran from a virtual computer so it has no BIOS to reset.
If the CD doesn't boot you will need to open the computer and remove the CMOS battery to reset the password
Dec 18, 2012 | Gateway Computers & Internet
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
How should the BIOS be set up?
This is the recommended way to do it.Turn on your computer and press F2 to enter the system setup. If you have problems with the Bios you have to get a Bios upgrade by getting software from dell then you can do the following.Reset the boot sequence to boot first from the floppy drive or the CD drive (depending on whether your flash BIOS update is supplied on floppy disk or CD).Insert the flash BIOS update floppy disk or CD, and reboot the computer. The computer updates the BIOS and then automatically reboots. mmediately press F2 to enter the system setup program, and reset the boot sequence to the normal setting. Then exit the system setup program.
Jan 09, 2012 | Dell Latitude C640 Notebook
I want to reset password of DELL Optiplex Gx-280 to enable cd rom on boot option .
remove the jumper, they have two pins only, turn on the computer, wait for 1 minute. The jumper is located close to the power plug, in the right side,
Apr 09, 2011 | Dell Optiplex GX280 (99301) Motherboard
Error Message: F12=Network Service Boot
The BIOS may have reset to the default settings. Sounds like this was originally a workstation on a Corporate Domain Network. Access the BIOS and reset the boot order for CD first, then Hard Drive - you can even disable Network as a boot option. Power spike won't affect the Hard Drive contents, but it can reset a BIOS. Your win2000 should be intact.
Mar 11, 2010 | Compaq Armada M700 Notebook
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Reset cmos and now it won't showhard driveand it
can u view the HDD in Boot sequence in BIOS boot seq...have u reset the BIOS/COMS using any tools...try reseting the BIOS boot seq to boot from HDD insted of floppy or CDROM...also check how many HDD is displayed in the BOOT seq...the machine normaly boots from HDD 0....
else try to boot from CDROM....and insert a BOOT CD/WinXP cd in the CDROM drive...
Dec 15, 2009 | HP (D7580-60003) Motherboard
How to reset bios password
You will have to pull the CMOS battery which is a small button sized battery on the motherboard, it powers the BIOS. Then just put it back in.:-)
Nov 15, 2009 | Dell Inspiron 1525 Notebook
Password
that is because the password in question that you are trying to get past is the BIOS password most likely. Verify that your computer is turned off, remove power cord from back of computer, and find the jumper near the Bios chip on the motherboard. It will usually be close to the battery ( another option, temporarily remove the battery for about 30 seconds, then replace the battery into its proper position ). Be careful when you do this as some battery sockets are a pain to work with. Anyway in nearly all cases, the Bios reset jumper is located very close to both the battery and the bios chip ( firmware ). Removing the Bios reset jumper and positioning it one pin over from the initial position will usually reset the bios and get rid of the bios password requirement. Always put the bios reset jumper back into its initial position before re-appying power to the motherboard. Be careful not to leave anything loose lying around on the motherboard or in the case, else you might fry the motherboard..
Once you have successfully managed to get past the Bios password, then you should see the computer start to boot up normally and prior to Windows boot up and in the Bios routine you can configure the computer to boot to CD first. In many more modern situations, the motherboard is already configured that way.
Feb 23, 2008 | Computers & Internet
Panasonic Toughbook 19 Laptop Convertible Tablet Logo
209 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
