Question about Acer Aspire 5735 Notebook
How to improve memory space in my computer
I have an ACER Aspire 5735 computer. It says it has 70GB still free..i have been deleting some files but it still says the same amount of free space..how do i increase memory space then?thnx!
  • carylgrey Jun 03, 2009
    yes,the recycle bin is empty.
    Master:
  • 409 Answers
Have you emptied the recycle bin?
Posted on Jun 03, 2009
  • Cosma Papouis
    Cosma Papouis Jun 03, 2009
    How big is the hard disk?
    What files have you been deleting?
    70Gb is Quite a lot. why do you want more space?
How to remove unwanted data from acer aspire 3003LCi?
Open your 'My computer' and select the stuff you don't want then press delete. If it is no longer used programmes, use the uninstall option for each one.
Feb 25, 2016 | Acer Computers & Internet
Acer aspire 1800 running very slow. Can I improve it's performance?
FIXING A SLOW COMPUTER
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Mar 30, 2013 | Computers & Internet
My acer aspire 5100 says its very low on disc space in C drive and now my email wont function. When I go to control panel programs and features it says that there are 1.77GB of programs installed but the C...
The simplest solution is to run Disk Cleanup as follows....
1. click start then hi-light All Programs > Accessories > System Tools and click on Disk Cleanup
2. wait while Disk Cleanup calculates how much space you will be able to free on ACER (C:)
3. in the Disk Cleanup for ACER (C:) under Files to delete:
4. click to set the check-boxes of the groups of files you wish to delete
5. at bottom of the list is the Total amount of disk space you gain
6. click OK button and on Disk Cleanup for ACER (C:) pop-up, click the Yes button
7. redo the preceding, clicking on the More Options tab to free more disk space from other areas.
Apr 02, 2011 | Acer Aspire 5100 Notebook
Thanks for the help in advance, i have two issues if u could plz help me with i have an acer aspire 5315 laptop with 80Gb memory. The thing is this memory is separated into two hard drives, C and D. 1)I...
Disk D is for storing recovery configurations. To see what happened to your memory, go to the root directory C: from your "My Computer" icon. Scroll to the folders in the root. Right click each folder and select "Properties." The drive will add up all the memory being used by that folder. Take notes on what you have and then drill down into the folders that seem to be using more space than they should be. Delete stuff you don't need. Let me know if you have more questions.
Dec 04, 2010 | Acer Aspire 5315 Notebook
Computer is slower than slow!!!!!! took 20 minutes for device manager to come up!!!!
Free Up Disk Space : clean up the unneeded temporary document and internet files on your computer. also use the Add/Remove Programs function on your Control Panel to delete unwanted software that are occupying space unnecessarily.
Fix Your Computer Registry : clean out your registry, you will need to get cleaner software to do a scan and fix. This software manage to restore computer speed back
Removing spyware should remove the irritating popups that they cause, and also improve your computer speed. One good antispyware that I would recommend is Spybot Search and Destroy.
I would recommend you to get a free scan on your computer now, and determine the main causes of your computer speed problems.
( If this solutions helpful to you please rate this)
Feb 26, 2010 | Acer Aspire 3000 Notebook
I have installed an extra 1G memory but it has not
Open "My Computer".
Right-mouse-click on the 'C:' drive.
Click 'Properties'.
A pie-chart will display, showing how much disk-space is "used"
and how much is "available".
Probably, the "available" pie-slice is less than 5% of the whole pie.
What Windows did was to "expand" the "paging" file, making it 1GB larger than it was before you added the RAM. So, the amount of "used" space on your C: drive is now 1GB _more_ than before.
So, burn some CD/DVD disks with some of your files,
and then delete the files, after checking that the disks are readable, to make more "free" space on your 'C:' drive.
Jan 09, 2010 | Acer Aspire 5315 Notebook
My drive c is full and drive d is empty on acer aspire 5633 wlmi what can i do
If your recycle bin holds any unnecessory files deleted previously, clean it. A file deleted normally goes to the recycle bin and doesn't give you back the space it holds. Thus to free that space you need to clear the recycle bin.
If the above method is not helpful open my computer right click your C: drive and click properties. You will find a disk Clean up button near the usage pie chart graph click it. It will calculate space to be cleaned and a disk clean up window appears in the files to delete list box select your choices. At this stage if you don't need your previos restore points except for the last one, it would free more space. To do that click on the more options tab at the top of the form and at the bottom you will see system restore. Click the Clean up button and confirm your action. Wait a while the buttons might not be responive at most for a minute depending on your computer's speed. Now move your mouse over the Ok button if it is active click Ok. This will give you some space back.
Otherwise Back up your files to the D drive first. What you do is copy the files from where you stored them to the D drive first. When done copying Delete the files on the C drive using Shift Key + Delete. ( I prefer copying than moving the through the cut command, because if in case the operation aborts in the middle of the process of moving, you will find it very hard to keep yor folder organizations as they were.
Nov 22, 2009 | Acer Aspire 5633WLMi Notebook
My computer is running out of free disk space. ive deleted several items but that doesnt seem to free much space up.
Get CClean and run it ...
Run the registery cleaner as well.
defrag yor hard drive
Things will improve for you
have www.pcpitstop.com scan your computer for additional guidance.
a
Oct 24, 2009 | Acer Aspire 5610 Notebook
Pc running slow
Hey defraging your HD will not cause you to lose any programs also you may need to do a fresh install. Also have you checked for viruses or mass sypware?
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
ACER 1360
Unless I am mistaken, the D drive or partition is the partition that contains the restore feature for yor laptop. This may or may not be hidden system files. As far as the available free space on your C drive, you WILL need to either delete files and/or backup and delete files. Image files, music files, cookies temp files take up a lot of disk space. Try this and I think you will find more free space. BPCS
Dec 23, 2007 | Acer Aspire 1360 Notebook
Acer Aspire 5735 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
