Question about Apple iPhone Smartphone
Opened Up iPhone, Now Touch Screen Doesn't Work
I tried to replace the glass on my iPhone (but ended up not doing so), and when I put it all back together (having taken the phone apart to try and replace the glass), the bottom half of the touch screen doesn't work. There are a few bands that don't work... it's not the entire bottom half, but most of it.
I tried taking it apart again and cleaning it really good, but to no avail. Re-putting it back together again DID fix a problem with the sensors that turn the screen off when you're on a call, but it did NOT fix the touch screen. I've tried the hard restart and stuff, but that doesn't work.
So I guess the real question I have is whether or not it's a software issue, or more likely something it's the hardware when I put it back together? The cable labeled "1" in the inside of the phone had a hard time staying in place. Is it possible that that is the problem? Or maybe one of the other cables? Or is it because debris got between the glass covering and the LCD Touch-part (I cleaned them both really good the second time and there is no visible specs or even fingerprints on the back side of the glass or the actual touch screen).
Thanks!
  • 4 Answers
SOURCE: broken touch screen lcd glass cover
Yes you can find the glass on Ebay and there is an iphone glass replacement guide online that shows you exactly how to replace the glass.
Posted on Dec 27, 2008
  • 630 Answers
SOURCE: My touch screen won't work after I've dropped it.
Probably damaged or loosened an internal connection. Similar thing happened to me and I needed a new motherboard.
Posted on Sep 19, 2009
SOURCE: iPhone Frozen inside ipod player
I had my phone freeze on me when i tried to put a picture up as wallpaper.... I did everything i could to unfreeze it including the holding down of both buttons....nothing worked! i had to wait over 9 hours for the battery to run itself out...which is a lot longer that i thought it would take
Posted on Aug 25, 2007
BUNNDOO
SOURCE: Apple iphone touchpad not working
RESTORE WITH I tUNES AND FIRMWARE 1.1.4, UNLOCK WITH ILIBERTY+ AND CHECK: JAILBREAKE, ACTIVATE, UNLOCK DOWNGRADE BOOTLOADER FROM 4.6 TO 3.9FB.THIS UNLOCK BASEBAND 4.05.05 OR SOMETHING LIKE THAT.BEFORE START ANYTHING GO TO ADVANCED AND CHECK PAYLOAD FIX NO WIFI EDGE.......(IF YOU DONT HAVE DOWNLOAD WIT ILIBERTY). PRESS GO FOR IT.WAIT UNTIL PHONE GO TO SLIDE TO UNLOCK.tHATS IT
Posted on Apr 25, 2008
my iphone touch pad in not working..
Posted on Aug 03, 2009
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
Feb 03, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Iphone touch screen doesn't work
(1)Check for loose connection on the digitizer screen. (2)Replace digitizer screen. you can buy Glass top + digitizer screen together. Check Ebay.com.
May 20, 2011 | Apple iPhone 3GS Black (16 GB)
The bottom part of my iphone touch screen doesnt work, i cannot use this part of the phone but everything else works? Any ideas on the problem or the fix?
You need to replace the digitiser of your phone which is the hardware which makes the touch screen work. This is attached to the glass of the touch screen and can be replaced in one. You can do this yourself using tutorial videos although I would recommend using a local iPhone repair shop as Apple will charge extortionate prices for this repair.
Mar 28, 2011 | Apple iPhone Smartphone
I have an 8gb Iphone that has a problem on the screen , it's like when you press on an ara of the screen does not work, some friends that has a dead line, it's not like you see a line on it, it's like the...
Okay try this, ive been doing this and making a TON of money on it recently... go you youtube and search for iPhone 3g (or whatever kind you have, 3g,3gs,2g) digitizer replacement.
you can go to ebay and search for iphone 3g digitizer and it will come up with tons of links to buy them, order one, its about $20 and then put it on like said in the youtube vidoes... i dont suggest using Direct Fix's or PDAParts.com's video...
Basic instructions,
take out two screws on bottom of phone,
take a suction cup the the glass of the phone and pull up,
once inside look for where the cables connect and disconnect,
unscrew 6 screws and CAREFULLY pull off the LCD,
go ahead an rip off all the glass from the plastic frame,
replace with new digitizer (glass),
and put LCD back on,
re-assemble and put screws back in the bottom (dont forget to plug cables in),
power up iPhone,
you good! (:
this will only work with iPhone 3g/3gs
original iphones your kind of just stuck with a paper-weight
May 11, 2010 | Apple iPhone Smartphone
I put a screen and glass on my iphone but it doesnt seem to be getting power to it. could it be a grounding problem. i dont have the screws yet.
I would recommend trying it out when you have all the necessary tools needed to complete the job. Until then, you leave your equipment open to ESD (electro-static discharge or static electricity) which seems harmless to humans but in actuality can virtually fry your sensitive internal components.
You might also have a faulty LCD/Digitizer/Glass combo. If this is a 2g model, then any of those components that need replacing require the entire set of 3 to be replaced to correct the issue (and not open up new ones).
On eBay many dealers sell the individual parts, but this is wrong and can further damage your iPhone down the line. The LCD/Digitizer/Glass combo is fused together from factory and any attempt to separate the combo typically ends in damaging one or more of the other components. Only the 3G (and I believe 3GS) allow for the glass to be a separate piece as the LCD/Digitizer.
If you own a 2G and bought one of these black-market individual pieces, I'd recommend you contact the seller and get a refund. They usually for about $40-80 and break more than they fix (if they work at all).
You are better off spending your money at Apple, as they will charge a $199 to fix (ie, replace your broken iPhone with a brand new model) and you'll get a 1-yr warranty out of it (along with a brand new iPhone) and no contract extensions for out of warranty replacements.
Mar 16, 2010 | Apple iPhone 3G
Broken glass touch screen to iPhone had a screw drive in pocket with iphone and it broke the touch screen glass
Hello.
Here's some info about your iPhone display repair:
Repair/replacement from Apple: $200-$250 The iPhone is covered under a standard limited one-year Apple warranty for manufacturer's defects, but is not eligible for AT&T's wireless phone insurance, which (for a $5 monthly fee) will provide replacement in the case of loss or theft, accidental physical or liquid damage or mechanical and electrical failure after the manufacturer's warranty period has expired.
Apple will repair your iPhone for the service fee listed below, plus $6.95 for shipping and handling:
  • 4GB: $199
  • 8GB: $249
Do-it-yourself: $150-$200 tools and loss of your warranty Several third-party companies sell replacement iPhone screens, which include the LCD and associated components. PDAParts sells the complete replacement screen for $150 and has a how-to-video for self-installation.
Hope this helps.
Jan 09, 2010 | Apple iPhone 3G Black Smartphone
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
Sep 19, 2009 | Apple iPhone Smartphone
The touch screen on mym phone wont work its jst not working all together it just stoped
hi friend,
  • Issue – Bottom half of iPhone touch screen does not work.
    Solution - Standard troubleshooting steps in order are power the iPhone off and on, Reset, Restore from backup, Restore as a new iPhone or not from backup and if no change after any or all, call Apple Care – (800) 694-7466 or make an appointment at an Apple Store to have this checked if there is one nearby.
  • Issue - iPhone “touch screen” dead.
    Solution - Connect your phone to iTunes and do a full restore, it will replace all information on your phone prior to your last syn. If it doesn’t help call Apple Care – (800) 694-7466.
  • Issue - The top half of my iPhone screen is not working at all
    Solution - If restore doesn’t work – you could schedule online an appointment with a genius at an Apple store
    http://www.apple.com/retail/
  • Issue – My screen cracked. How much would it cost to get it replaced?
    Solution - Terrible situation but Apple doesn’t warranty the glass. This would be a minimum of $250 to get fixed out of your pocket.
Hope one of the solution helps…
thank u for using fixya
please rate me..............
regards
sivaranjini
Sep 12, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Broken touch screen lcd glass cover
Jun 08, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
702 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
