Question about Xerox Phaser 8560MFP Laser Printer
RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
I JUST NEED THE RESET INSTRUCTIONS FOR THE MAINTENANCE KIT I JUST INSTALLED. THANKS! how I can reset admin (web) password for phaser 8560? please help.
  • Xerox Contributor
  • 185 Answers
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
  • HamburgerMan Jan 13, 2011
    You can reset the maintenance counter to 30K by using one of these:
    http://skyforms.netfirms.com/cgi-bin/rec...
    It works for 108R00676 all models including 8500/8550/8560/8580/90 8860
    8560MFP and 8860MFP
  • 20 Answers
There HAS to be a reset unit on the market that the seller is not cashing in on by this one time ****. all they do is reactivate the kit when its returned and sell it again. any leads to an infinate use chip resetter? i have one for my epson inkjet made by DCM in the uk
Posted on Oct 25, 2011
Master reset xerox 8560 printer
Your Administrator Guide book should have these instructions listed for you. It should be on the CD's that came with the printer.
If you have lost/misplaced them, you can download the guides from the Xerox.com website.
The steps below are what I did from my laptop as a Repair Technician:
1. Connect a crossover cable between the PC and system. To print an Event Log or Runtime Log:
2. Verify the system is Ready.
3. Use the system's control panel to enable AutoIP:
a. Select the system Setup menu.
b. Select the Connection Setup menu.
c. Select the Network Setup menu. 5. The page should now print.
d. Select the TCP/IP Setup menu.
e. Set AutoIP to On.
f. Exit the menu so the system is Ready.
4.
NOTE: To print the Connection Setup or Configuration page, select the system Setup
menu.
Reset the system to cause AutoIP to assign a new IP address (cycle power or select
Restart system from the Shutdown menu).
5. After the system's IP address is set, test communication by sending the "PING" com-
mand.
6. If the test fails, install a different cable and retest.
Sep 27, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Xerox 8560 Maintenance Kit remaining life
You're probably lucky that your machine still works after using non-xerox products, in any event, I'd suggest a new Xerox Extended kit, it's possible the non-xerox product didn't work as intended and your replacement kit wore out faster because of it.
The kit contains a micro chip which "resets' the counter in your machine, as the count comes from the kit, not the machine itself, however, the machine is capable of sensing when the maintenance kit has reached end of life regardless of count.
Additionally, you should check the wiper blade (you can see it when you remove the maintenance kit) for excessive wax buildup which generally means the machine needs service.
These are great printers, very fast for the quality. They can be quite a nightmare to service due to so many systems which have to be exact!
My #1 advice on this product is if you own one, never ever move it while it's hot! or you could face a very expensive repair!
Mar 27, 2014 | Xerox Phaser 8560N Laser Printer
With no warning, my Xerox 8560 abruptly quit print...
I don't believe there is anything to do but replace the maint kit. There is a chip on that maint kit and it lets the machine know how much life is left. when you replace it the chip will reset the count. IT SHOULD HAVE WARNED YOU TO ORDER A NEW ONE WITH PLENTY OF WARNING!
May 18, 2010 | Office Equipment & Supplies
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
8560 DN Replace Maintenance Kit
the maintenance kit keeps your melted crayons from sticking to the roller. You know the smell... and no you need a new one.
Sep 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560
you could also try rebooting the machine. i've seen it happen that the new maintenance kit was recognised as new after a reboot. choose the standard shutdown method...
Jun 22, 2009 | Xerox Phaser 8560N Laser Printer
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
The maint kit resets the counter when it is installed. You may have gotten a bad maint kit or the black plasstic part that the roller slides into is bad. That is where the connection is to reset the counter.
Harry
Mar 18, 2009 | Xerox Phaser 8560MFP Laser Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560MFP Laser Printer Logo
6,214 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
