Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Sony wega 50" wont turn on and no sound it goes to standby
The standby light then flashes in groups of 3
  • Sony Master
  • 586 Answers
   According to the symptom self diagnostic system recomandation is :
   Lamp cover            error 3 times
- Lamp cover is not fastened securely.
Therefore please check the area of fault mension above, this will solve your problem.
Thanks for using fixya.
Posted on Jun 03, 2009
  • 822 Answers
Check horizontal out transistor.
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
My sony wega tv will not stay on,it goes on to standby alternating between a green light and a flashing red light.I cannot find the manual. What should I do?
i have a 50 inch wega that i just replaced the lamp. it wont stay on. i lose the pictuer and sound after a min or so then lose it for a min then it comes back on???
Jun 26, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light flashes 50 times then lamp light flashes, no picture or sound
standby light flashes 7 times then lamp light flashes, no picture or sound
Nov 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I got a replacement lamp, but red light still binks and there is no picture. Why?
hello if the lamp cover is not mounted securely the self -diagnostic funcation works and the power/standby indicator flashes for 3 times .when you've corrected it the power/standby indicator goes out and the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Replaced lamp still wont turn on
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
NOTE: You may have to replace the lamp also if the issue persists.
Check this Link for more information.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C36267
Good Luck!!!!!!!!!!!!!!!!!!
Sep 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv turns on then off immediatly..standby light then is on
hey i have the same thing with my tv how do you fix it do you know?
May 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My tv shut off now it wont turn on on the lamp light is flashing
A little more info is required bfore we can help much. If you attempt to turn on the set, the standby light should blink a repeated code. If you can post that count here, we can use that to tell you what circuit has the problem. If that light does not come on at all, that too is good info.
Thanks,
Dan
Feb 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
159 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
