Trane air handler cycling rapidly
Air handler on Trane heat pump will intermittently cycle on and off rapidly. It sounds as if the motor tries to start but can't then stops. At times, it will do this for minutes on end -- cycling on momentarily, then off for five or ten seconds, then do the same again. If I move the fan switch from Auto to On, the fan starts immediately and runs just fine. Air handler is in closet near family room, so cycling is VERY annoying. Replaced thermostat, but no difference. Does anyone have a suggestion?
  • 1 more comment
  • kirby90 Jun 03, 2009
    I mean the fan that circulates the air.
  • kirby90 Jun 04, 2009
    I wonder whether it's actually the relay. As I mentioned in the post, if I change the fan switch on the thermostat from Auto to On, the fan starts without any problem and stays on.
    Here's a little additional info: model number is TWV048B140A1. Unit was manufactured March 1992.
  • vikketer
    vikketer May 11, 2010
    When you say air handler do you mean the fan that circulates the air or the compressor in the condensing unit
  • 614 Answers
Depending on the age of your Trane unit. The fan relay has a time delay. This is a solid state board on the relay. Most of the time they stick on or off. Check for loose wires. But start with relay.
Posted on Jun 04, 2009
  • James Stopp
    James Stopp Jun 06, 2009
    Iworked for Trane for 15 years. OK In the thermast when it call for cool it brings the fan on thru the Tstat. You may have a bad fan switch in the tsta. . If yhis is an old mechanical Tstat. That is your problem. I have certain procedures I use to troubleshoot. Try a new tstat. Pick up one at Home Depot. If you want to call me. I can walk you thru problem. Ok James 251-269-1443. No problem
Trane XR15 not starting. Has power. There is a contact switch that when engaged the system fires up but coil gets cold but not circulating through the air handler. Could it be capacitor related?
So the contactor pulls in outside, the fan and compressor both start?? Then you say the coil gets cold... what coil is getting cold and is this a heat pump and are you trying to cool the house???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 08, 2017 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
How do I fix my Trane air handler to keep it from turning off about 20 seconds after being commanded to turn on?
Some units require both a start and a run capacitor. It's possible the wrong capacitor was replaced. It's also possible to add a run capacitor to a system to keep the fan running. There is an outside chance the bearings in the fan motor are worn to the point it's time to replace the motor.
Mar 29, 2015 | Heating & Cooling
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
I installed 18 seer heat pump&air handler with communicating stat,i turned power on to air handler,not heat pump,stat learned air handler&heaters properly.turned power on to heat pump,stat does not...
Dont know what equipment you have but yes of course there is a fix. Turn power off to air handler. cycle power to heat pump and be sure the board is configured properly to match your outdoor unit. Then turn power on to indoor unit and likely go through system setup once again. provide model numbers of all communicating components if more problems.
Dec 10, 2017 | Goodman Heating & Cooling
Trane AC Compressor fan cycling on and off.
it depends on the tempareture you have set that is why it was going on and off
Sep 09, 2009 | Heating & Cooling
Is it normal for my 4 ton Trane compressor to rapid-cycle (about 5 seconds) during the hottest part of the day?
it must be over heat compressor,try to decrease temp on thermostat,probably will work
Jul 05, 2009 | Heating & Cooling
Heat Pump Cycles On and Off and Air Handler Noisy
I am pretty sure you have a low charge and the pressure switch is kicking it off. probably just a pound or two however the accumulater will sometimes hold more.
Mar 27, 2009 | Bryant 463AAC008BA Air Conditioner
Defrost Cycle Problems with Heat Pump
That's what a heat pump does. The problem to me sounds like you don't have a big enough heater inside.
Apr 30, 2017 | Weather King 10AJA4201AH Air Conditioner
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
999 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
