Question about Samsung SGH-D500 Cellular Phone
Broken car adapter plug
Hey there,I was curious if you knew which side was positive on the car adapter harness(the side that plugs into the phone,its a samsung). The wires pulled out of the plug and when I took the plug apart,you cannot tell which is positive or negative. If you can help that would be great,please and thanks. Kevin
    Problem Solver:
  • 15 Answers
Every car plug should have a nozzle like thing, thats the front, if the wire is pulled out it doesn't matter. no problem with +ve or -ve. you join anywhere no probs.
Posted on Jun 03, 2009
Need a wiring diagram for a 1997 Hyundai h100 stereo.
Your best bet is to get an harness adapter that will let you wire the stereo then plug it directly into your factory harness. Check out
Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Good luck
May 21, 2016 | Hyundai Cars & Trucks
Where are the freeze plugs located on a 1995 Ford Aerostar
from under the vehicle they are round holes in the side of the block above oil pan and below the heads.
Nov 06, 2012 | Cars & Trucks
My acer aspire 7720G shut down random
Wait a minute. What?
From what I read;
1) One wire of the AC adapter (Charger) is hot to the touch.
'.....when I touch the charge one part of the wire is very hot."
2) AC adapter checks out as far as voltage is concerned.
"I tested the charger voltage and everything is ok."
3) "Sometimes when I touch the charge appear the icon...Could it be the charger broken wire?"
Does this mean, "Sometimes when I touch the AC adapter (Charger), the battery icon appears."?
Battery is CHARGING icon?
Could it be a broken wire in the power cable TO charger?
Uh, yeah.
1) AC adapter NOT plugged into the DC Power Jack, plug the power cable of the AC adapter into power.
Multimeter set to DC Voltage, and proper scale, red Positive lead to harness wire that goes to DC Power Jack's center pin;
,black Negative lead of multimeter, to wire that goes to DC Power jack's inside cylindrical metal shell;
Now gently wiggle the cable from the AC adapter, TO the DC Power Jack of the laptop.
Do you get an intermittent reading?
2) Also, how did you replace the DC Power Jack? What steps did you take?
http://www.dcpowerjacks.net/catalog/index.php?main_page=product_info&products_id=1291
Did you reuse the wire harness, and solder it to the DC Power Jack?
Have a lot of experience in desoldering/soldering?
What tools did you use?
25 Watt soldering iron?
.025 or .030 rosin core solder?
Desoldering Tool, or Desoldering Braid? (Solder Wick)
Side Cutters instead, and slightly shortened the wires of the DC Power Jack's harness?
(Then tinned the wires, and soldered the wires of the DC Power Jack harness, to DC Power Jack?)
Damp sponge, and cleaned the well tinned No.2 chisel tip, of the soldering iron, frequently? Used rosin solder flux?
Center pin wire (Positive), of harness cable TO DC Power Jack, was soldered to the center pin of the DC Power Jack?
Negative wire of cable TO DC Power Jack, was soldered to the inside shell of the DC Power Jack?
(Cylindrical shell, inside the DC Power Jack, that surrounds the center pin of the jack)
Sure there are no cold solder joints?
Not trying to 'browbeat' you, just am curious.
1) IF you are SURE you have the polarity correct, of the wires in the harness cable, that goes to the DC Power Jack;
,and you are SURE there is no broken wire, in the cable from the AC adapter (Charger) TO the DC Power Jack;
,and you are sure you made good solder joints;
I suspect the power correcting chipset on the motherboard, to be bad, or perhaps a Diode.
One example of the chipset I am referring to. This one is used in a lot of laptops. May not be used in yours, but gives you something to refer to when looking for a bad chipset, in the power stage, on your motherboard,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
Usually when bad the top of the chipset will be blackened, or bubbled.
A Diode is a one way valve for electricity. When they go bad it is visually obvious.
http://www.mouser.com/ProductDetail/Vishay-Semiconductors/BA479S-TAP/?qs=j6bfm3UnQnzfWUXqYnsQ9LdHLayQ%2fSwFGlGUXEDAB5w%3d
Post your findings in a Comment.
Regards,
joecoolvette
Jun 10, 2012 | Acer Aspire Computers & Internet
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
Kenwood KVT-514 installation
your bluetooth tuner should have come with an adapter plug so you can plug it into a different port so both can be hooked up simultaneously
Jul 26, 2010 | Kenwood KVT-514 Car DVD Player
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Apr 22, 2010 | Kenwood KDC-422 CD Player
How to hook up the wiring on a 1997 chevy blazer for towing a trailer?
Hey how ya doin! underneath the rear of your blazer on the drivers side you will see some wiring running by the frame rail tword the back bumper. about 8 inches or so up the harness you will see a large clip holding it together. You just unhook this, go to your local auto store and buy the harness clip that clips inbetween these two connections. Poof instant trailer lights. The harness you need to buy is around 20 bucks and its a cinch to put in. Even if you dont quite understand what I am saying here, once you buy the piece and look under your blazer, you will see just what I am talking about. The only catch is the boughten harness only comes for the standard four point hook up. If you need the big round rv style plug you will have to adapt up to it. These adapters cost another 25 to 30 bucks. Hope this helps. Later, Clay
Mar 22, 2009 | 1997 Chevrolet Blazer
Installing a mp3 player in a 1989 toyota hiace van
go to pepboys or any place they sell car radios you can purchase an adapter harness that will plug into your factory wire harness that will give you a list of the wires to make the job simple the harness cost about 5 or 10 bucks good luck....
Sep 07, 2008 | Sony Xplod CD Player w/MP3 Playback...
Head phone
that means it's broken. is it just a headphone adapter, or the kind that plugs straight into the phone? you can buy a headphone adapter on ebay cheap, maybe 3-4 dollars.
Jan 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Samsung SGH-D500 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
