Question about Sony KP-53S65 53" Rear Projection Television
Sony big screen rear projection
I have green oval lines all over screen, what can i do to remove them?
  • 1,694 Answers
Re: Sony big screen rear projection - Sony KP-53S65 53" Rear Projection Television Projection Televisions
Replace green CRT....
Posted on Oct 24, 2007
0 characters
3 Points
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
Jun 22, 2008 | Sony KP-51HW40 51" Rear Projection...
service call, sounds like the coverage.
Dec 26, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Red Green Blue Across The Screen
Yes, especially big screen. It sounds like convergence is out of lign. Try menu and straighten out, wait until set is warm first.
Dec 06, 2007 | Sony KP-46WT520 46" Rear Projection...
Sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
Nov 06, 2007 | Sony KP-51HW40 51" Rear Projection...
Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Oct 19, 2006 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
35 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
