Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Rooms r hot
Three rooms sit at 27 degrease and the wall control set point is 22 degrease is this a sensor prob or programe prob
  • 822 Answers
Check gas and settings for cooling.
Posted on Jun 03, 2009
Outsite temperature next to clock light turning orange
check near front bumper for a tiny black sensor somewhere near number plate the sensor seems loose or bad connection on wire ,not 100% sure where sensor sits but pretty sure its a bad connection on plug to sensor as it is a common prob on bmw when sensor loose /bad connection show minus 40deg when its hot outside and display plays up vw polos have same prob
Jan 15, 2014 | Volkswagen Cars & Trucks
Mr.Steamer Commercial Steambath CU750A temp is to high it is out of control
There are only 3 likely causes. The first and most likely is the room sensor inside the shower. This is a resistive type sensor that communicates the temperature in the room to the controller via ohm ratings. There is an equivalent ohm rating for every degree of temperature it correlates to and that is how the temperature controller knows what temp it is in the room. Often in commercial steam rooms clients tend to spray cold water on the sensor which causes damage and alters the ohm rating to the point where the sensor is relaying incorrect room temps to the controller, causing high or low temperatures. Normally when the room is hot, it causes the alloy metal of the sensor to be hot. When cold water is sprayed on it, it immediately bring down the temp of the alloy and the thermal shock warps the metal causing the resistance values to change. Set your multi-meter to ohms and remove the sensor wires from the back of the controller. You will do your ohm reading on the sensor wires. Check the actual room temperature with a thermometer. At room temp 77 degrees you should be getting 10,000 ohms, at 100 degrees you should get 5827 ohms, and at 120 degrees you should get 3759 ohms. Note as the temp goes up the ohms go down, this should help you determine if your sensor is good. The other possibility is your steam solenoid valve is stuck in the open position. Simply check if there is voltage running to the solenoid. If there is no voltage but the room is filling with steam your solenoid is stuck open and needs to be replaced. The last is the controller, and by process of elimination if the sensor and steam solenoid are good then the controller may be the issue.
Feb 02, 2012 | Mr Steam Mr. Steam Commercial Steambath...
Hi. I have a Maytag CWE4200ACB wall mount oven that seems to have a circuit board/timer problem. When the oven is turned on and temp set you can hear (at the control panel) one click and the "on"...
Hi.
The clicking noise comes from the control board relays. The board has three relays. One for for bake. One for broil. One for light/fan auxiliary functions.
Try switching on only bake or broil. If one of the two elements (either bake or broil) gets hot, then the problem is either element or timer board. Make sure that the element has continuity at the Ohm meter.
If both bake and broil do not work test first the oven temperature sensor located inside the oven cavity. Make sure that impedance of the sensor at room is about 1.1KOhms . If sensor is open or shorted, replace the sensor. If sensor reading is OK test wiring and elements for continuity and eventually replace the control board if the rest is OK. Even if door switch should not affect regular programs, check the door switch reading impedance or jumping it.To test wiring test continuity of red and black lines. Check black line between power cord and relay board. Test with particular attention the oven temperature sensor, that is a common cause for your symptoms. Here the part:Long Oven Sensor Kit
Here a wiring diagram for your oven.
Here all parts and diagrams.
Regards.
Ginko.
Nov 15, 2011 | Kitchen Ranges
I have a GE wall oven that does not heat up to the set point. Model JKP13GP. 75-100 deg cooler. The temp prob measures a little less than what is required. 1.00 in ice water, 1.07 @ room temp and 1.27 in...
No the sensor is going to be the problem...at room temp it should be between 1060-1100 ohms. In boiling water it should be somewhere around 400 and in icewater it should be appx.2500-3000
The sensor needs to be replaced. The part number for it is WB21X5301 it can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
GENE
Sep 26, 2011 | GE Ovens
HOW DO i PROGRAM MY TV, SO i CAN SET IT UP FOR wii GAME CONTROLLER?
game control sitting in your telivision and control it
Apr 10, 2011 | Sylvania 6427TE 27" TV
Gant get past language selection
This screen requires you to use motion controls, meaning you have to actually have the sensor bar set up properly, and then physically point the wii-mote at the buttons you want to select. You cannot use the arrows.
If you are having trouble getting the wii-mote to point, be sure that your sensor bar is in the correct position, that you are at least three feet away from the sensor, and the remote is one. If all three of those things apply, turn your system off, let it sit for a minute or two, then turn it on and try again.
If the problem persists, try syncing the remote via the remote's instructions.
Mar 08, 2011 | Nintendo Wii Console
Where to I place the sensor on a wall mount heater? Also, how do I get the heat to go into the other rooms? It seems to me to be hot in the immediate area where it is placed. Thank you.
Thermostats and sensors should be installed in spaces with airflow. This means it should not be on a wall where it may be blocked by an open door or similar objects. It shouldn't be where the sun can shine directly on it (and make the sensor believe it is warmer than it actually is), not should it be on outside walls (and make the sensor believe it is colder than it actually is).
If it is a thermostat, a comfortable height is about 5 feet. This makes it easy for adults to read and set, without worrying about young children changing the settings after your leave. If a simple sensor, this 5 foot height applies still - but lower is just as good. Remember, since heat rises, the air on your face while standing may be a couple degrees warmer than when sitting. A sensor left on the floor will cause the room to feel much warmer than the desired temperature when standing and to a slightly lesser extent while seated. This also translates to higher heating costs.
As mentioned above, heat will naturally move up. Getting it to move side to side requires additional equipment. Fans do the job inexpensively and very nicely. Place them in higher locations (where the heat is) and set the speed to a low setting, aimed into the cool space. This gently moves the warm air into the cool space - without causing a breeze that may actually feel cool on your skin.
I hope this was helpful - good luck!
Nov 10, 2010 | Heating & Cooling
The outside of my fridge is hot, and the freezer is warming up. If it's the compressor or the "sealed system" the repair visit is totally covered, but if it's something else, I'll have to pay $80. just to...
The side walls of these units are the condensers where heat is rejected to the room air. It is normal. The temperature in the freezer section will rise after a defrost period and the side walls will become hotter right after a defrost is completed due to heat load on the system. Defrost time is only 18-22 minutes normally but the refrigeration system will run longer to recover. Free air circulation is absolutely necessary around these units and nothing should be stored on the top with a towel or other items covering any point.
Jul 29, 2008 | Refrigerators
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
57 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
