Question about Sony Cyber-Shot DSC-P52 Digital Camera
Sony DSC P52 won't flash Error Code is E:91:01 tried reset already
Won't flash has error code E:91:01 already tried reset. Everything else works fine.
  • Vanisha Jan 19, 2008
    My sony T7 is also flashing an Error Code E:91:01 i have also tried reseting my camera but doesnt seem to work? I'm running out of options?
  • 398 Answers
When you pressed the reset, if it cleared the time and date that button is working. If that did not clear the error it is a hardware fault, meaning that a circuit has failed and parts will have to be replaced.
A local camera store might be able to find the problem but you will have to carefully weigh whether these older camera is worth the cost of repair.
Sorry! I hate giving bad news.
Posted on Apr 05, 2008
Cyber shot DSC-W561 error code E:91:01 - how can reset normal condition?
Download the service manual from elektotanya.com and find the complete explanation to the error codes. This is a service center job.
Nov 04, 2012 | Sony Cyber-Shot DSC-W560 Digital Camera
Flash won`t work
Error ( E:91:01) is off COMPLETE FLASH UNIT which contains part No. along with description is given below:
A-1166-208-A ST-133 BOARD, COMPLETE
(For DSC-W50)
A-1231-877-A ST-133 BOARD, COMPLETE
(For DSC-W55)
For your convenience please see the pic below of required part:
7985bce.jpg Thanks
May 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flashing E62:12 on screen?
Check error still comes after RESET camera by going into camera Menu -> Initialize ->OK
E62:12 is error code means "Lens Overheating". Camera has "Angular Velocity Sensor" on its main board and that can be cause of problem. If still error blinks, contact Sony Service Center for proper fix as this will requires special tools.
Feb 25, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
DSC W55 Error code E:91:01
Hi,  Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY.
  For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Jan 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber-shot dsc-s30
try a different memory stick, if no problem with the new stick, use a pc to run a quick format on the old memory card... should solve the problem.
May 01, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
E:91:01
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Flash no more working: error code
You must have an E:61 or E:91 error. You will need to send it back to Sony but, that is what warranties are all about. I am sure it will be fixed quickly and for free!!
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
