Question about Acer Aspire 5500 5570-2609 Laptop
Bios setup is not comeing & error is remove disk or other media alt+clt+del
Give me solution of acer 5500z is not booting and bios is not come
  • 822 Answers
Check your key board.
Posted on Jun 03, 2009
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
Tip
Fatal issue: Error loading operating system
<p><b>Issue:</b><br /> <p>Error loading operating system<br /> <p> <br /> <p> <br /> <p> <br /> <br /> <img src="matrix12_3.jpg" /> <br /> <br /> <p><b>Cause:</b><br /> <p>The MBR (Master Boot Record) either could not find a bootable partition or the bootable partition points to an unreadable on inaccessible part of the drive. This issue occurs prior to the start of any Windows code. <br /> <p>It can be caused by a power-failure while the disk is in the middle of writing, a virus damaged the entry, a failing disk drive or a serious software bug damaged the partition entry (although Windows typically protects against this). This issue cannot be easily caused by any action you performed, unless you turned off the power without going through Windows shutdown.<br /> <p>Although not stated in the message, press Ctrl-Alt-Del to reboot.<br /> <p><b>Workaround:</b><br /> <p><b>Change boot media:</b><br /> <p>If you are booting from either a DVD, CD, diskette or a USB drive, remove the media and boot from the hard disk. The media is either damaged or is not intended to be bootable.<br /> <p><b>Set the Correct BIOS Boot Choice:</b><br /> <p>The BIOS may be configured to boot from the wrong device. If you suspect this, the device boot order can be changed in the BIOS setup. Be aware there little consistency in BIOS setup operations, even with the same manufacturer on different models. As such, these instructions are bit less precise than we'd prefer.<br /> <p>1. Reboot and enter the BIOS setup. Often the BIOS displays the correct key to use briefly on screen or you may need to refer to the computer's user manual. Typically you hold down the Del, Esc, F1 or F2 key immediately after booting. <br /> <p>2. Look for a section on Boot or Booting. Often this appears on top menu. Select the Boot option, and if necessary the Boot order choice. The Boot order choices should list the order of boot devices. Typically the CD is the first boot device with the hard-disk typically second. The diskette may also occur before the hard disk, which is acceptable, although this will slow your hard disk boot by a few seconds. Avoid USB and network boots before the hard disk unless you know for sure you are using them (which is exceptionally rare). <br /> <p>3. Save and exit the BIOS. It will force a reboot. See if this change corrects the issue.<br /> <p><b>Check Hard Disk and Cables </b><br /> <p>If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.<br /> <p>It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.
on Jan 24, 2011 | Computers & Internet
I Cannot repoot my disk by pressing F2
What are you trying to do ?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
If you need more help with this or if i have missunderstood the problem post a reply
Hope this helps
Nov 19, 2012 | Dell Dimension 4600 PC Desktop
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
T22 disk read error
Sounds like the Operating System is corrupt. I would re-format the hard drive and re-install the OS that should solve the problem. If not then the Hard drive needs to be replaced.
Jan 23, 2012 | IBM ThinkPad T22 2647 Notebook
Getting error nvidia boot agent 249.0542
It seems the Basic Input Output System (BIOS) settings have been changed on this computer.
This type of error message occurs when the computer is trying to seek a network device to boot from, or is set to boot from a removable disc or other media that have bootable files stored on them that the BIOS requires prompting or selection for in order to proceed to the boot stage.
First check that there is no disc in the Optical (CD/DVD) Drive -> if there is remove it -> restart the computer by pressing and holding down the Control (Ctrl) and Alternate Value (Alt) keys 2 fingers of your left hand -> press the Delete (Del) key with your right hand -> release all 3 keys -> tap either the Del or the Function 2 (F2) key 2-3 times as the first white writing appears on the black background of the screen after powering up -> the (Power On Self Test (POST) procedure will then redirect to BIOS Settings (often referred to as Setup) -> use the keyboard arrows to navigate to Set Default Values -> press the F10 key -> press y for yes or Enter for OK -> test the boot process again.
If the computer still does not boot properly repeat the above steps to enter the BIOS Settings/Setup again -> use the keyboard arrows to navigate to Boot Menu -> arrow down to Boot Device Order -> look at the BIOS Control Options at the bottom or side of the window to find the appropriate control keys for changing the order of the boot devices (often the + and - keys, the F5 and F6 keys, the Page Up [PgUp] or Page Down [PgDn] keys -> move/promote the Hard Disk Drive (HDD) to the First Boot Device position -> press F10 -> y for yes or press Enter for OK -> test the boot process again.
Nov 20, 2011 | Acer Computers & Internet
Acer travelmate 2420 error "remove
go to BIOS by pressing F10 , DEL or F2 key and go to advance and chose first boot device as hard drive , save and exit.
Jul 10, 2011 | Computers & Internet
Acer 3050 won't boot. Disk Read Error
looks like hardware failure.
find out what harddisk exactly you do have in the bios :
- press Del or F1 or F2 during booting, goto IDE devices, look for the model, size (in GB) etc.,
write down (the manufacturer could be: samsung, seagate, maxtor, fujitsu...)
- then change order of boot devices so that cd/dvd-rom drive and /or 3,5 '' floppy drive boots
before the harddisk, exit saving changes (F10 or Esc)
- then get diagnosis program from the harddisk manufacturer's homepage,
copy that to a bootable floppy disk or burn it to a cd-r/cd-rw which must be bootable
- boot from the cd or floppy, run diagnosis tool, both short and long test, what does it say then?
- if hardformat is available, perform one
- might work now, at least the hd will be recognized
-setup new windows installation.
have fun
Apr 21, 2009 | Computers & Internet
Acer Aspire T180
check your removable media disk drives and make sure that you don't have like a jump drive or CD-Rom that the computer doesn't like. If that doesn't work, enter the BIOS setup (usually F2, F12, ESC or something like that....check the bottom of the screen.) and find the Boot Order settings & move hard drive to #1
Jan 08, 2009 | Acer Aspire™ T180 PC Desktop
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
