Question about KitchenAid Dishwashers
KitchenAid KUDIO1FL DW control panel is not responsive (ie indicator lights do not light when buttons are pressed). There is water on the bottom of the DW. Like it just died, in cycle. The circuit bre
Hello, My KitchenAid KUDIO1FL DW control panel is not responsive (ie indicator lights do not light when buttons are pressed). There is water on the bottom of the DW. Like it just died, in cycle. The circuit breaker & power outlet are fine. Thinking it probably is a fuse-like condition. Is there a fuse within the washer? If so, How would I replace it? Thank you bigblue_92@hotmail.com
First see the fuse it it is dead replace it
nor take out the plug from the switch it is connected
Posted on Jun 03, 2009
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
How do you turn off replace filter light on freezer door panel?
If you're referring to the water filter indicator light that goes from green to yellow to red when it's time to change the filter, you press and hold the WATER FILTER button down until it blinks 5 times. The indicator light will change from red to green when the system is reset.
Feb 13, 2011 | KitchenAid KSCS25FKSS Side by Side...
Hi, I have a Kitchenaid KUDI01TJWH0 dishwasher that failed. Any of the front control buttons like Heavy-Normal-RinseOnly or even the HiTemp-EnergySaver .... when you press any of these, the corresponding...
Hi Your Problem is Probably The Control Panel. Not The Electronic Control. The Plastic Piece Across the Top of the D/W, Which Tells the Control What to do But You Must Realize These Parts Can Be Very Expensive. John H. Been in this Business 35 Yrs
Sep 29, 2010 | KitchenAid Dishwashers
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    KitchenAid KWVU265YBA
    had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
    Feb 25, 2008 | KitchenAid KWVU265YBA Kitchen Hood
    Maytag MDBH950AWS Dishwasher won't start
    We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
    Thank you.
    Jan 17, 2008 | Maytag 24 in. MDBH950AWS Built-in...
    Kitchenaid dw clean light still blinking/ machine won't run...
    I tried the following sequence, as recommended on a similar blog and it worked!
    Open door
    Quickly press :
    Hi Temp Scrub
    Energy Saver Dri or Heat Dri
    Hi Temp Scrub
    Energy Saver Dri or Heat Dry
    Close door
    All lights should come on
    then clear and revert to cycle.
    Feb 28, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
    Dishwashers Logo
    497 people viewed this question
    Top KitchenAid Dishwashers Experts
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
