Question about Canon PowerShot S410 / IXUS 430 Digital Camera
The switch from camera setting to view picture taken setting isn't working properly. It just stays on the camera setting.
The switch from camera to view pictures taken on the canon powershot s410 doesn't seem to be working. It just stays on the camera setting.
    Sergeant:
  • 270 Answers
Try to read tha user manuel and try again
Posted on Jun 03, 2009
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
Canon powershot A520 doesn't work in camera mode. I can look at and edit pictures in viewing mode, but switching to "camera" won't let me take pictures... in this mode it also lets me view pictures already...
Hi!
Do other buttons work? If so, the switch could be broken because it sounds it doesn't switch to the CAMERA mode, just stays at the VIEW mode.
If you're not experienced in repairs, you should give it to a local repair shop or Canon service center.
Sorry for the bad news. I repair these cameras very often.
Tom
Sep 27, 2009 | Canon PowerShot A520 Digital Camera
Last picture preview
the fix should be in the set-up menu. Look through for "post-view", which should control whether the image stays on the LCD after you shoot, and for how long.
Feb 07, 2008 | Olympus Stylus 720 SW Digital Camera
To view still photos taken from canon dc-210 dvd camcorder
Sounds like you're using the "cine" setting.
Switch the camera on.
Move the "cine / photo" switch (it's just above the joystick) to the "photo" position (i.e. to the right).
Use the joystick to move between images.
Good Luck
Feb 03, 2008 | Canon DC210 DVD Camcorder
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Unable to take Pictures
So, you're using Ni-MH batteries already, once you've turned it on and then you have to press on the PLAY button to view pictures, i need you to double check the battery type option of your camera by doing the steps below:
- Press MENU
- Scroll to the right until you are in SETUP 2
- Go down to Battery Type
- Switch it over to Ni-MH (for Rechargeable batteries)
- Select Alkaline (for Non-rechargeable batteries)
- Press MENU/OK for changes to be saved
Turn off camera for a few seconds so settings will be refreshed.
Turn on camera without pressing on the PLAY button to double check if it works.
If it does not work still, try to turn on again camera and immediately press on PLAY button to view pictures. Try to press again on PLAY button so you'll be on the mode to
take a picture.
If it still does not work, can you please try Non-rechargeable batteries (Alkaline) with your camera if it won't work with the Nickel-metal Hydride (Ni-MH) Rechargeable batteries.
Make sure you have set properly the battery type of the camera under SETUP 2 for Alkaline.
take a picture.
If it still won't work, then you have to send the camera for Repair.
Register camera online:
- Go to www.samsungcamerausa.com
- Click on Customer Service
- Register under Option 2 Box
- Fill out the required info
- Read instructions
- If website asked you to upload a receipt, just skip that
step and leave it blank
- Take note of the ASC address and online ticket number
that will be generated at the last step
- Turn-Around-Time will be 7-14 business days
Do the following:
- Include a copy of receipt in the box to avail of the warranty
- If you don't have any receipt, include a copy of credit/debit card statement/cancelled check that was used to purchase the camera
- Exclude all accessories when sending camera for repair
(No batteries, memory card, strap, cables, manual, CD)
- Write the online ticket number on top of the box
- Use another box and sealed it properly to avoid damages during shipment
- Check repair status using Online your zip code and phone number as you proceed on the Repair status of the website
Sep 14, 2007 | Samsung Digimax S630 Digital Camera
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
