Question about Watches
Disney watch band
How do I adjust this watch band it has no pins.
4 Suggested Answers
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
  • 43 Answers
SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Posted on Jan 05, 2009
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
0 characters
1 Points
Montres Carlo. How can I shorten the band?
? 5:51
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
How to Resize / Adjust a Watch Band - YouTube
? 6:39
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
Jan 19, 2016 | Watches
How can i set the time for a disney accutime watch LR626 Customer Questions & Answers, Inc.Disney Kids' FZN3630 Frozen Anna and Elsa Watch With Graphic Band. by Disney ... Question: i have no directions for setting the time either in or on the pkg.Missing: accutime ‎lr626
Disney Kids' FZN3630 Frozen Anna and Elsa Watch With ... > Watches > Girls > Wrist Watches, Inc.
Rating: 4.2 - ‎68 reviews
The digital time makes it easy for kid's to read. It light's up when you push it. The Frozen theme is adorable. This watch does not look cheap at all. It will adjust to ...
Dec 27, 2015 | Disney Watches
How to fix a plastic disney watch
Yes, you can solve your watch problem from ankaka . It is a great place of digital watch as well as many electronic products. Different modern types of digital watch and solution in case of problems are available here.
Apr 03, 2013 | Disney Mickey Mouse Watch with Square...
Need to replace my leather watch band on my goofy watch with an authentic disney band. it is leather with no characters on the band & underside is stamped with disney made in china. Need size &...
If you need an authentic Disney watch band, try asking at a Disney store. However, non-Disney watch bands will fit this watch and may be both better quality and less expensive. Almost any jewelry store, department/discount store jewelry counter, or shopping mall watch kiosk will be able to measure your watch and determine the right size band. Many women's watches in this general style use a 14mm or 16mm band, but you should measure your watch to make certain.
May 05, 2011 | Disney Goofy Brown Leather Strap #D075S007...
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    How to make a relic watch bracelet a little smaller?
    No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
    Sep 18, 2009 | Relic 0504648FA
    Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
    Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
    To shorten the band you have to:
    Extract the pins.
    Take link(s) off.
    Join the rest of band together and drive pins back.
    Jan 01, 2009 | Fossil JR8096 Wrist Watch
    Casio watch band adjustment
    Check the Citizen web site:
    You can skip the part about removing the split tube. Instead of their pin pushing tool, I used a short piece of straight pin held with long-nose pliers while I squeezed using medium sized channel-lock pliers. A helper to hold the watch would've been good.
    Jun 30, 2008 | Watches
    Fossil watch band adjustment
    throw the ******* thing away
    Dec 26, 2007 | Fossil AM3695 Wrist Watch
    Band adjustment
    I was able to take use a push pin (thumb tack) to get out the (split) pin. I put the thumb tack in the hole of the pin I wanted to remove, place the thumb tack upside down on our counter top and gently but firmly push the pin out. It only has to push out an 1/8 of an inch and then you can pull it the rest of the way. Thanks to the diagram that "guest" posted above - I copied and pasted: in the browser and it showed me how the pins work in the wrist band. Didn't need all of the fancy tools. (:
    Aug 18, 2007 | Fossil CH2331 Wrist Watch
    Watches Logo
    145 people viewed this question
    Top Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
